Question about Vivitar 283 Flash
Ready lamp on 283
I haven't use my unit in over 3 to 4 years. The unit charges up and the ready lamp comes on. But after a few seconds, the ready lamp starts to blink off and on. Is the ready lamp suppose to stay on solid or is it suppose to blink.
  • carusoswi May 11, 2010
    I just purchased a used 283. The ready light on my old 283 purchased back in the mid '70's blinks after the unit powers up. The blinking is very steady.
    This new unit blinks very quickly for a few seconds, then, the light goes out for five seconds, then comes on steady and remains that way until I turn the unit off.
    I did some testing by leaving the unit on overnight. From what I can tell, the batteries last as long in this unit as they do in my original, so I guess this anomaly presents no problem.
    Any comments?
    Caruso
  • 4 Answers
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Posted on Nov 15, 2008
Toshiba theatrewide hdtv blinks 3 green and orange then 2 orange and orange lights
You need to first look from the side(left) and or back to see if lamp comes on even for a few seconds.
Average life span for the model indicated (52hm84) is 2,000 hours or 2 years.
The lamp is the place to start and it is customer replaceable so if you remove it and find it damaged (shattered inside) you know what your problem is.
Let me know what you have tried.
Mar 17, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Vivitar 283 won't flash, exept through pc terminal
Hi if it is a Japanese 283, CAREFUL, you are working with ~300V
remove the sensor from the front. Short out the terminals at 7 o'clock and 11 o'clock with eg a paper clip, and then charge up the flash . Short the centre terminal with the one at 7 o'clock. If the flash fires, then it probably needs a replacement hot shoe from ebay. If it doesn't, it is a simple job to fix for an electronics worker. Manuals are available on ebay.
I repeat, careful with the Japanese flashes, you will have ~300 volts near you fingers, so if you are less than 100% confident that you won't blow the top of a finger (or worse), get an electronics worker to look at it.
Don't use the ebay hot shoes on a 300 volt flash, you will have the 300 volts out in the open and ready to bite you - have a look how well hidden the second contact is on the Vivitar plastic hot shoe.
Good luck the Feral Photographer
Dec 14, 2008 | Vivitar 283 Flash
Acer pd726w projector beeps
I hate to echo this problem, but did either of you ever find the solution to beep code? Our church has had the projector for just two years and the lamp must have only about 400 hours on it.
Oct 20, 2008 | Office Equipment & Supplies
Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Mar 10, 2008 | Vivitar 283 Flash
Zenith E44W46LCD 44 in. Rear won't start
The buzzing is the ballast for the lamp trying to light the bulb. From what you've described it is a lamp failure. It's not that hard to change but you'll have to obtain a new lamp first. You can try and buy it from LG (800-243-0000) but I'm not sure if they'll sell to a consumer. Then you have to reset the lamp timer after you replace it. Hold the mute on the remote and the enter button on the tv at the same time for about 8 seconds and a screen will come up asking if you want to reset the timer. Just follow what it says to reset it.
Jan 02, 2008 | Zenith E44W46LCD 44" Rear Projection...
Wont come out of standby
The problem is most likely a defective lamp. See your owners manual on lamp replacement as this can be done by the consumer.
Dec 05, 2007 | LG RU-44SZ51D 44" Rear Projection...
Vivitar 283 Flash Logo
179 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
