Question about Yamaha HTR-5730 Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
The Yamaha I have is not part of the product choices provided.  I have a Yamaha RXV 595 receiver. When I have had parties and turn up the volume, the receiver shuts down.  I have Bose Accoustimass III series and Mission 700-2 speakers.  I do not know if the system gets overheated and that is why it is shutting down.  Or, is it a problem with the speakers versus the receiver.
  • jeanfly61 Oct 30, 2008
    If the speaker wires are reversed, how am I getting any sound?
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Posted on Oct 30, 2008
  • BUDDY1123 Nov 06, 2008
    They just works like that at low volume obviously. to directly answer your question, I don't know. I'm not a electronics tech. I've just had that problem before. also, if the volume is all the way up never turn it down fast to all off. that will blow the speakers. been there too.
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 07, 2014 | Yamaha RXV-350 Receiver
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Own an RXV-367 & want to connect an external Amp to power deck speakers. How ?
Assuming the external amp is analog and has its own volume control, run RCA cables from "Audio Out" to its input.
Jun 18, 2011 | Yamaha RXV367 Receiver
My yamaha rxv 1700 7.1 ch amplifier with defenite speakers shuts of at 40% of volume it gives a the option check the wiring how to solve this problem
Open the unit and inspect for cold solder connections. Use a non-conductive tool to poke the circuit board for the bad connection. Please keep in mind that when you do this, the unit has to be powered up - be cautious of the live circuit.
Dec 29, 2010 | Yamaha RX-V1700 Receiver
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Hello, it is worth checking that there is adequate ventillation around the unit, especially if it is in a cabinet. Also check that there is no dust clogging the vents on the unit. Another cause for overheating is using speakers that require far more power than your receiver can provide, or speakers with an ohm rating that is lower than the amplifier provides. Also, check to see if any wires to the speakers are crossing over as shorting will cause the amplifier to overheat and cut out. Hope this helps.
Jul 26, 2009 | Yamaha RX-V520
Yamaha HTR-5730 Receiver Logo
505 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
