posted by jacquie1 on Sep 09, 2006
I am having a problem with my machine, every time I try to select a program to run it sticks on the test cycle and no matter what I do, switching it off and on etc, it will not run. Any Ideas?
Best Solution
posted on Nov 27, 2006
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 18, 2007
if your machine shows "test" then you need to cancel test program, I was told that you need to prass the "start/cancel" button ten the power button in either order not sure which order but it does work. this cancels the test and you need to then restart as normal.
hope this helps
hope this helps
Solution #3
posted on Sep 23, 2007
Hotpoint recommend turning off the mains for ten seconds and then switching it back on before you press both buttons for five seconds. This is because like all computer driven mavhines they have a memory and the machine needs to forget.
Info direct from hotpoint. 100%
Suggest a new solution for this problem
Post a New problem for Hotpoint Aquarius WD640 Front Load
Email this problem
Email this problem
This Problem Also Relates To:
Hotpoint Aquarius WD63 Front Load All-in-One Washer / Dryer
Hotpoint Ultima WF860 / WF860G / WF860T / WF860P Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer
Hotpoint GE VWSR4150DWW WASHER 4 SPD 15 CYC 4 TEMP8 BRAND IN STOCK
Hotpoint BWM20 Front Load Washer
Hotpoint WMA33 Front Load Washer
Hotpoint WMA35 Front Load Washer
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD640 Front Load All-in-One...
ON/OFF & Time saver Button...
Hi, just out of the blue the... Answer This...
when drying clothes the clothes
when drying clothes the clothes... Answer This...
hotpoint wd640 front loader
initially went into test mode... Answer This...
hotpoint wd440 heating but not...
please help, my wd440 is not... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
