Question about Gateway Computers & Internet
If this is a new machine: try this
if there is already sensitive data: try this
Posted on Oct 30, 2008
Gateway login
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 26, 2013 | Computers & Internet
How do I recover a lost password for Windows
<p><b><span>Question 1:</SPAN></B><br> <p><b><span> </SPAN></B><br> <p><span>hello everyone .My niece recently bought a new laptop, and she decided to use a password to log on, but now she has forgotten her password and she cannot log on. Is there anyway to work around this or do we have to have it formatted.</SPAN><br> <p><span>thanks in advance.</SPAN><br> <p><span>From by hulkster</SPAN><br> <p><b><span> </SPAN></B><br> <p><span> </SPAN><br> <p><span>Most of us are usually confronted with this problem-forget our Windows password and have no idea what to do. Now,let's get acquainted with this issue.</SPAN><br> <p><span> </SPAN><br> <p><b><span>1st Method: </SPAN></B><br> <p><span>The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:</SPAN><br> <p><span> </SPAN><br> <p><span>Start system and when you see Windows Welcome screen / Login screen, press "ctrl"+"alt"+"del" keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.</SPAN><br> <p><span> </SPAN><br> <p><span>Now you can reset your account password from "Control Panel -&gt; User Accounts".</SPAN><br> <p><span> </SPAN><br> <p><span>Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.</SPAN><br> <p><span> </SPAN><br> <p><b><span>2nd Method: </SPAN></B><br> <p><b><span> </SPAN></B><br> <p><span>Windows XP and further versions also provide another method to recover forgotten password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:</SPAN><br> <p><span> </SPAN><br> <p><span><a href="">How to create and use a password reset disk for a computer in Windows</A></SPAN><br> <p><span> </SPAN><b><span> </SPAN></B><br> <p><span>If all fails,Simply go to <b><a href="">Windows Password Key</A></B> website to download this tool,it can help you 100% recover your lost password.</SPAN><br> <p><span> </SPAN><br> <p><b><span>Windows Password Key 8.0</SPAN></b><span> is considered as the best tool to reset local administrator and user passwords on any Windows system. It creates a password recovery CD/DVD, USB Flash Drive for home, business and enterprise. And most of all, it's the most popular and safe solution for resetting your Windows password until now.</SPAN><br> <p><b><span> </SPAN></B><br> <p><b><span>How to use:</SPAN></B><br> <p><span> </SPAN><br> <p><span>(1). Login to a computer that can link to Internet. Download windows Password key and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.</SPAN><br> <p><span> </SPAN><br> <p><span>(2). Insert the newly created CD/USB drive to the locked computer.</SPAN><br> <p><span> </SPAN><br> <p><span>(3). Reboot the locked computer and press'F2'or'Delete
on Dec 03, 2010 | Computers & Internet
How to recover Windows XP password?
Setting Windows XP password can help us prevent others logging into our PC without permission. However, every coin has two sides. on the one hand, it helps us very much in our privacy protection. On the other hand, For the sake of carelessness or accidence, we are perplexed with the problem of losing password. Thanks to the development of technology, many tricks are available to <a href="" style="font-weight: bold;">recover Windows XP password</a>. In some cases, recovering from a lost password can be very easy though.<br /><br />In order to show completeness, we start with the simplest tips that can help you regain access to a locked account.<br /><br /><span style="font-weight: bold;">You can login with another user account</span><br /><br />If you have another user account or you share your computer with others, things will be much simpler. Log into the Windows with the other account and perform the following steps:<br />1. Click "Start" button<br />2. Click "Run"<br />3. In the "Open" field, type "control userpasswords2"<br />4. Click "OK"<br /><br />Windows opens a user accounts dialog. Select the user with the lost password and click the "Reset Password" button. Enter a new password, and click ok. Click ok once again and you are ready. Now you can log on to your account using the new password.<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Recover Windows XP password with a boot disk or a bootable CD.</span><br /><br />If there are no other users on your machine to unlock your account, you need to boot your pc from outside your usual Windows XP environment using a boot disk or a bootable CD. But this progress often presents very quickly and if you are not proficient with technology, it will be hard for you. Then how to solve this headache problem easier?<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Ask the help of third party Windows XP password recovery tool</span><br /><br />Of course, you will need access to another PC to create a boot disk or bootable CD. Nowadays, many tools support bootable USB. Easily burn the BIOS image file to the CD/DVD/USB Flash Drive, reboot the PC with the CD/DVD/USB Flash Drive, then you regain access to your PC. Here let's take Windows Password Recovery Enhance for example. Only four steps, we can log into the PC again.<br />Step1. Download Windows Password Recovery Enhance and install the program on the other unlocked computer.<br />Step 2: Burn bootable CD/DVD or USB flash drive<br />Step 3: BIOS setting<br />Step 4: Recover Windows XP password<br /><br />Related: <a href="">Windows Password Recovery Blog</a><br />
on Dec 01, 2010 | Computers & Internet
I need to fix my gateway password
Lost Windows password:
  • Log in as Administrator (Try safe mode if you don't see Administator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password.
Aug 29, 2012 | Gateway MX Computers & Internet
I can't get my laptop to boot up.
It sounds like your Explorer.exe is corrupted or missing. when you see your desktop wallpaper then you can try to open task manager my pressing Ctrl+Altr+Delete keys all at a time and now click "new task" and type Explorer.exe and press enter. if your Explorer is OK then your icon and other thing should land up if not then restart computer and try to open computer in safe mood by pressing F8, if you can open then try restoring your computer to earlier date by going to start----program---accessories----system tools -----system restore.
Aug 21, 2012 | Gateway MX6447 Notebook
Gateway window recovery
Forgot your Windows Vista password? Don't worry - it happens to a lot
of people.Vista and Windows 7 allow you to create a password reset
disk.If you installed Windows XP, boot up Windows XP in Safe Mode and
log on with the built-in administrator account.Besides,using Windows
Password Reset
,it is easy and safe ,and support all systems.
Feb 11, 2012 | Gateway LT2030u Netbook
I have a ZX4931-31e gateway all-in-one. i did a system restore back to factory settings. when it rebooted i was asked to log in and i don't know what the reset administrator password is? i tried...
Have you tried a blank password for the administrator. Just press enter when administrator pops up. If that does not work, try administrator. That should solve your problem.
Thanks for using FixYa!
Aug 02, 2011 | Gateway ZX493131e Notebook
Unlock a 450rog computer
Basically, at Windows XP Welcome Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu which you can specify User Name and Password. In the User Name text box, key in “Administrator” (without quote) and leave the Password field blank. Then press Enter or click on OK. If there is not password protects the Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Dec 12, 2008 | Gateway 450ROG Notebook
Forgotten password
If you lost your windows password, try a program called "ophcrack-win32-installer-3.0.1.exe" or "ophcrack-xp-livecd-2.0.1.iso". These will crack and show any windows based usename and password on your computer.  If the problem is the bios password, for starting your laptop, then you will have to reset the bios (check manual) or remove the battery pack and on board Li battery to reset Bios. I would check the manual first. On old Toshiba laptops you could jump the parrallel pins to reset the bios, not sure on the Gateway. I will check further.
Sep 30, 2008 | Gateway M305CRV Notebook
Computers & Internet Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
