Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
FI on fisher & paykel
Machine is blinking f1 and will not stay off
  • 136 Answers
Do you have their web site or phone number. try unplugging the machine for 1 hour and then plug back in and see if that does the trick
Posted on Oct 30, 2008
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
The code F1 keeps blinking and I can't shut it off.
f1 means u have a leak on your machine and the water has triggered the flood switch underneath the lower drawer. if u need more help please reply.
Apr 27, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Our dishwasher displays F1 with a wrench???
check the water pressure is coming through first
Mar 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher Paykel F1 is blinking on both drawers - how do I resolve this without calling a service tech?
f1 is a fload code the bottom drawer has to come out and dry up the water make sure the power is off
Jul 13, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Fi code washer wont stop beeping
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
May 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
70 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
