Question about Samsung HCN653W 65" Rear Projection Television
Blue convergence I just replaced the convergence board after it went out. My tv will now come on like its suppose to, but the perfect focus still will not complete, going only to 44%, and the blue is bowed top and bottom. why did the new board not correct the problem with the blue? During perfect focus it appears like 2 small notches are missing on the bottom verticle line like something is blocking it. Please help!
    Sergeant:
  • 395 Answers
Try going into manual convergence from the menu and selecting factory default this will reset any user attempts to converge. then try the prefect focus again. another famous problem with these sets are cloudy fluid and blue is the #1 failed fluid failure of all. I've replaced more fluid in blue guns than I can shake a stick at. cloudy fluid will not be bright enough to activate the sensors for perfect focus. look down into the blue gun when on the image should be clear and focused if the fluid is cloudy the image will be muted and not clear.
Posted on Jul 15, 2014
  • 50 Answers
SINCE YOU HAVE REPLACED THE CIRCUIT BOARD,THE NEXT STEP WOULD BE CHECKING VOLTAGES GOING TO THE CONV. BOARD COMING FROM THE POWER SUPPLY CIR. BOARD.....IF NO VOLTAGE METER,,SOMETIMES, THERE ARE FUSES ON THE POWER SUPPLY CIRCUIT BOARD THAT SUPPLY THE NEEDED VOLTAGES FOR THE NEW BOARD YOU JUST REPALCED...UNPLUG THE SET,,CHECK FOR A BLOWN FUSE----I THINK THERE IS 2 OF THEM--ONE FOR A NEGATIVE VOLTAGE AND ONE FOR A POSTIVE VOLTAGE FOR THE CONVERGENCE BOARD..GOOD LUCK--SORRY, MIGHT NEED A TECH...TUNICA
Posted on Oct 30, 2008
Problem I can't intall my product many times its turn off itself all my installation are well install with my blu-ray ARC tv to ARC Blu-ray are well install I don't understand why its turn off itself
The blue ray turns off or the TV? and what models?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Televison & Video
To begin with I have Dish network my TV went off and since then in order to have picture and sound i have hookup HDMI cable and also video cable to have picture and sound
You need to set up the dish box for the correct resolution ie 720/1080 etc.
Jan 05, 2017 | DISH Network Televison & Video
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
How do I determine if it a power failure or if it is a faulty SC board (TNPA5335)?
That does nost sound normal. I would take a look at the output of the power supply. Look at your electrolytic capacitors on the power supply board. Do they look like the top of them has popped up? If so you can get replacement capacitor kits from www.lcdalternatives.com
Jul 09, 2014 | Televison & Video
How do i watch my tv with a broken remote
You can buy a universal remote and program it to work with your TV. I have always had good luck with RCA universal remotes. You can also program the remote to run your cable/sat box and your DVD/blue ray player. You could also go to the web site of the company that made the TV and order a new remote. This would be more expensive but the remote would run all the funcitions while the universal may not.
May 24, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
Do a 2001 GE projection tv have a lamp in it?
Yes course there is a lamp . You can order one from ebay for around $10 .
Apr 21, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Samsung HCN653W 65" Rear Projection Television Logo
100 people viewed this question
cce772000
Level 1 Expert
