Question about LaCie F.A. Porsche (301177) Hard Drive
My external won't show up on my laptop
I'm trying to load the disk on my laptop for my external, for some reason my laptop won't show any icons saying it's connected
  • Anonymous Jan 07, 2009
    my external won't show up on my laptop
Some laptops don't have enough power to just use the firewire cable. try also using the USB power supply that came with the HD
Posted on Nov 12, 2008
My laptop says "location is not available" if I want to access my external. Please help, it shows everything on there but it just don't want to open.
Perform a total power recycle to both external disk and your laptop.
I have faced this when I try to access the Seagate 3TB hdd connected to my router from my MacX but have not accessed for a while. The disk is shown but the contents throw " location does not exit"
May 26, 2016 | Western Digital 2TB WD ELEMENTS USB...
Asus laptop with Win7 64 bit asks to format WD external drive while other laptops have no issue running it - how come?
you are not swapping from mAC to PC and back , right?
try other USB ports.
many external drives do not run with out an external power pack.
elements, use 4 diffr. 18watt power packs, Are you using the right one?
so plug that in ,first. then plug in USB , w7 must go Ding dong
or the USB is DEAD. (use this as #1 fact to follow)
then put ear to the case of drive, hear it spin?
if not ,there is no power, for SURE.
solve that first.
ok, it spins. (soft whirl\'g sound, do this when new to memorize how GOOD sounds)
for a tests, leave the USB cable , not connected.
let w7 boot to the desktop.
now plug in the USB HDD, cable.
W7 goes, Ding dong.
then see the USB icon in the tray, does it see the drive>?
Y/n?
click on that tray icon, i see USB to ATPI bridge then...
My externals (have many) shows as Z:/external below , bridge....
if not , USB is failing.
yes, ding dong, yes Icon, yes see drive above.!
then go to disk manager, type those 2 words in the run box.
start +run " disk manager"
CP(controlpanel)+computer management +disk management.
does disk manager see this spinning drive.
mine shows,. DISK 2 and is letter coded Z:
if not , the USB port is not working. or the drive is not with power.
if disk manager shows the drive, the assign a letter to said drive
now program manager can see the drive, with this letter Z.
it dont need to be Z , per ce\' but that letter is a nice flag.
step by step.
oops it has green tech, that means it goes to sleep.
make sure you turn that off first. or it may not show up at all.
it\'s so green its , invisible?
wd on their DL page has a spin down utility, use that.
Oct 03, 2013 | Western Digital Elements 2 TB USB 2.0...
Sony HD-EG5 is not detected on my laptop
Download the "password protection manager" software from the Sony website. When installed it will detect your Sony External hard drive.
Jun 13, 2013 | Sony 500gb External Hard Disk Drive, Usb...
Acer external hard drive problem code 10
Try chkdsk or download Testdisk and run to ensure the disk is in good order.
Feb 27, 2013 | Acer Computers & Internet
Computer won't recognise ethernet connection from router
I don't know the make. model, of laptop or your OS? Open network connections, is it enabled? Is there a Network Icon in the Tray Notification Area? You really do not need a Disk to connect. Just plug in the ethernet and boot the machine.The computer should ID the connection, if it enabled and working properly. If not open Device Manager , Network Adapters and enable the ethernet adapter.For further assistance respond to post.
Dec 18, 2012 | Computers & Internet
My hard drive was working properly earlier and now i plugged it into my laptop and it says that i need to format it for it to work, it shows the icon for it on my computer but won't open. I don't...
The disk is dying - hardware defect. Last attempt to save some of your files: take apart the casing and extract the actual hard disk from it; put it directly inside a desktop and try to access it from there. If the disk isn't recognized or you get an IO error when you try then the damage is too great. If you only get a format error you could try this program
http://www.ptdd.com/recoverdeletedpartition.htm
Jul 17, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
My Toshiba Satellite 2805 S301 USB 1 port, does not recognize my Passport external Hard disk drive. What can I do to solve this problem ? Thank you, very much for your assistance.
Hi
assuming that the external hard disk is usb
i would try this
plug in the external hard drive
then go to device manager
then hover your mouse at the top of the box
and look for a icon that says scan for new hardware
then hit the scan icon
your laptop may or maynot recognize the external hard drive at this stage
now leaving it plugged in restart the laptop
and with any luck windows will now recognize it
good luck
hope you get sorted with it
Mar 20, 2011 | Toshiba Satellite 2805-S301 Notebook
Acer Aspire One D250-1042 shows desktop wallpaper but won't load
Start by logging on as the Administrator so you can check the Task Manager and find out what Application or Process is monopolizing the system.
If the system is still unresponsive boot into Safe Mode. (Press F8 before the Windows startup screen appears.) If everything is fine in Safe Mode type MSCONFIG at the Command Prompt and start disabling features until you find the culprit.
Last resort, buy or borrow an external USB CD/DVD drive and use it to reinstall Windows.
Important: Reinstalling will ERASE the hard drive.
If this helps please vote for my solution.
Jan 19, 2010 | Acer Aspire One PC Notebook
New Dell Internal / External USB Floppy Drive 1.44Mb
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
LaCie F.A. Porsche (301177) Hard Drive Logo
182 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
