Question about Legacy Audio LA720 Car Audio Amplifier
Crazy Car Amplifier
I have a JENSEN JXP460, not the best car amplifier but it USED to work. I was driving to Boston one night and had the music on, high but not MAX and the the Sub shut off and kept making single thud noises which I noticed went with the amplifiers blinking power light.
when plugged in it is red then turns green quickly, but goes right back to red
I unwired everything changed the ground checked all connections and only hooked up the power, ground ,and remote wire. It does the same thing. I used my multimeter and measured 12V at the power and about 11V at the remote so it is receiving the power.
I did a little homework online and read that the problem my be a blown transistor. Without any power hooked up I checked out the transistors.
I found 0 OHM Resistance checking MOSPEC F12C20C ANA and MOSPEC F12C20C 1A side by side. Of the 3 terminals of each transistor if I measure the outside two of either I will get 0 Ohms. Am I getting at anything here? What is my next step?
Thanks for any help out there guys.
-Scott
  • tosims7 Nov 03, 2008
    Wow that was such good advice man I never thought of that!
    think you should be posting on buyaNewone.com
    To anyone else I enjoy the challenge I am looking to fix this, or at least give it a shot.
    Guru:
  • 200 Answers
To be honest with you, your best bet is to buy a new amp.  cheap amps are cheap because they plan on you buying another one when they don't last.  save up and buy a nice amp, thats my advice.  if you really want to fix this one i wish you luck, but i've never worked on an amp before, just install and troubleshooting, so in my experience this one's fried.  But i'm sure it could be fixed, the question is wether or not it is worth it?
Posted on Oct 30, 2008
I need a wiring diagram or pinout for my jensen LXA300 amp, thanks
Look at this image this is the best that i found online ....if this is not the exact amplifier all of the jesen 300w amps seem to be made the same so the wiring should all be the same.
if u still are not sure post a picture of the amplifier connections.
Sep 23, 2013 | Jensen XA92 Car Audio Amplifier
Where can i get the hi-input plug jensen 600w amplifier? amplifier made by audio-vox, model jpa460, 10 prong socket
You will have to call Jensen. They normally don't come with amps anymore as most users prefer the RCA input for better clarity and sound quality.
Aug 11, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Wiring diagram for a LXA400 Jensen power amplifier??
Power wire to battery
Ground wire to body of car
Remote wire to power antennea wire on radio or power amp wire on radio if you have aftermarket radio
get back with me for any more ?'s
Jun 05, 2009 | Jensen LXA400 Car Audio Amplifier
VRCD400-SDU
Hi Theaternut,
Best guess is that your source button or whichever button changes from cd, to Tuner, to usb, to Card, is shorted, and needs cleaning.  Its like the button is always pushed.
see if you can carefully dsiassembly the reciever to get to the circuit board behind the button I speak of, and clean it.
Oct 19, 2007 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Bidging
You can't bridge 4 channels into one channel. You can bridge the amp to two channels and drive one dual voice coil speaker.
The owner's manual is available from Jensen.
Oct 11, 2007 | Jensen LXA400 Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen Amplifier..4 x 50WRMS at 4 Ohms
This sounds like you need a ceramic noise suppression filter/ferrule on the Power line to the amp. You should be able to get a suitable one from most car audio shops. Hope this helps, please post again if you have trouble getting one :)
Mar 28, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen vm9411 no sound
Check to make sure your vehicle does not have a factory amplifier. If you used a fit kit with wiring harness. try looking at how many wires were used in the factory unit compared to haw many you are using now. see if there are extra wires in the vehicle. If there is extra wires it is a pretty good clue the vehicle has an amplifier and will have to be rewired.
Sep 01, 2006 | Jensen VM9411 Car Video Player
Legacy Audio LA720 Car Audio Amplifier Logo
128 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
