Question about Maytag Neptune MDE4000 Electric Dryer
Changing plug I have a Maytag dryer de4000. I have a red terminal, a white, and a blue. The cord has a black a red a white and a teal. How do i connect this?
  • Daniel Hanson
    Daniel Hanson Apr 22, 2009
    I have same cord and a four prong plug in only my cords are Black, Red, white and green please answer this for me because I am not getting any heat from this dryer hardly and I think it is hooked up wrong
    President:
  • Maytag Master
  • 2,651 Answers
Your cord has 4 prongs , assuming your outlet also has 4 prongs.red to red, white to white, black to blue, and the "teal" gets hooked to the green ground ******** the rear of the unit
Posted on Oct 30, 2008
How to wire a four prong plug in
red and black power phase wires on the cord go to the 2 outer terminals of the 3 terminal power block on the dryer,then the white neutral wire on the cord goes in between the red and black wire on this power terminal block ,then the green wire on this cord goes to any metallic point of the dryer which is the safety ground wire
Jul 28, 2012 | Maytag Dryers
I have a 3 prong plug and 3 wires w/ connectors and they are not marked.which one attaches to the red, white, black terminal in the back of the dryer?
Looking at your dryer's wiring terminal block, you'll see three separated terminals. The red and black cord wires attach to the two outer terminals (it doesn't really matter which goes where), and the white one gets attached to the center one. You may even see smaller white wires coming from the back of the terminal and disappearing into the dryer. Make sure the terminals are securely tightened before you plug it in.
Dec 24, 2010 | Maytag Centennial 7.0 Cu. Ft. 7-Cycle...
Wires for the maytag dryer are black, yellow, blue and white. We need to swap the cord for a 4 prong connection - are the yellow and black the hot wires - the white neutral and the blue the ground wire????...
The red and black wires of the cord go to the outside two terminals. The white on the cord goes in the middle. The green goes to the frame. Red and Black on the cord are L1 and L2, White is Nuetral, and green is ground
Nov 26, 2009 | Dryers
Changing 220 plugs need discription of positive and negitive to dryer
If you are installing a 3 prong cord , then the 2 outer wires , are the power lines , and the center is the neutral . On the dryer , the center wire connects to the white wire on the terminal block . The 2 outer cord wires . 1 connects to the black wire terminal on the block ( outside terminal ) , and the other outside wire , connects to the red ( outside terminal ) on the block . Its the same if you are installing a 4 wire cord , except the green , connects to the ground screw on the dryer itself .
Oct 25, 2009 | Maytag Dryers
How to hook up a cord to the maytag neptune dryer with no color c
The 2 larger outside wires are the Hot wires (Red and Black). Connect them to the Red and Black terminals on the dryer (They can be reversed, it does not matter as long as one is on the Black and the other is on the Red terminal) . The smaller middle wire is the Neutral wire (white) and will connect to the white terminal on the dryer.
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
3 to 4 plug dryer
Not really sure what you are asking. But if you trying to hook the cord up... Green and white go to the middle terminal Then black or red to either side it doesnt matter which.
Jan 30, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Used maytag electric dryer installation question
First off, you should be wiring your power cord directly to the terminal block inside the dryer. If someone just cut off the cord that is terminated inside the dryer, and you are attempting to splice the new cord onto the old one.. you are making a mistake.. take the new cord and bond it directly to the terminal block inside the dryer. If you have a new 4-wire power cord, you are probably dealing with a red/black/white and green wire. ( assuming it is a four prong plug).. The black and red wires are the power lines themselves and should mate with the red and black wires inside the dryer. The green ( is frame ground) and is normally bonded to a stud near the terminal block or the dryer frame. The white is the neutral line and is normally tied to the terminal in the middle and between the red and black tie points.. In line splices should not be done on this appliance.. Hope this helps..
Sep 06, 2008 | Dryers
Maytag Neptune MDE4000 Electric Dryer Logo
100 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
