Question about KitchenAid KGST307 Gas Kitchen Range
Cleaning inside glass door, kitchenaid range
There is dirt on the inside of the glass panel on the front of the oven door. I've removed the door, removed the bottom and side frames. The glass seems like it should lift out. there are two small tabs on the top frames over the glass. The rubber gasket across the top seems to be what is holding the glass. The glass would just pull out from under these two tabs if it were not stuck to the gasket. Does the top frame of the door have to be removed to safely remove the glass. I can't find any screws for the top frame, perhaps they are under the glass. Do I just have to keep working at pulling the glass until it releases from the rubber gasket ?
  • KitchenAid Master
  • 2,651 Answers
You do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Posted on Oct 30, 2008
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Jun 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
How to clean between the glass in the oven door. Kitchenaid KERC
You need to remove the screws on the bottom of the oven door and the glass panel will come off
Apr 04, 2009 | KitchenAid KERC506 Electric Kitchen Range
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid superba Stove Door
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
Aug 04, 2008 | KitchenAid KESC307 Electric Kitchen Range
How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Jun 16, 2008 | KitchenAid Kitchen Ranges
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
528 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
