Question about GE Advantium SCA1000H Convection / Microwave Oven
Ge sca1000h need to replace the light that comes on when you open the door or when you microwave
  • nvossler Oct 30, 2008
    I was able to figure it out last night. There is no entry from the outside. I had to take the grill off and then take a screw out of the sheet metal, then bend that piece up and then I was able to get to the light. I had to pinch the cover for the light to lift it out.
    Thanks anyway.
  • 50 Answers
UNPLUG THE MICROWAVE FROM THE ELECTRICITY,,,,AGAIN,,,UNPLUG THE MICROWAVE FROM ELECTRICITY---NOW ,SOMETIMES YOU CAN SEE A TRAP DOOR LOCATED ON THE OUTSIDE OF THE CABINET --THE SIDE WHERE THE LIGHT IS ,, MAY NEED A PHILLIPS HEAD SCREWDRIVER,,THE LAMP IS THERE--DID I SAY ---UNPLUG THE MICROWAVE,,YES ..IF YOU ARE NOT COMFORTABLE WITH THIS --DON' T TOUCH IT !!!!!! TUNICA
Posted on Oct 30, 2008
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000 will not come on
Hi!
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If that doesn't help then there might be a burned wire or a component that can only be found out by opening it up, which is not recommended.
Please rate the solution if you found it helpful.
Thanks
Rylee
Feb 08, 2009 | GE Advantium SCA1000H Convection /...
No power on GE Profile Spacemaker II Microwave Oven
SWITCHES ARE THERE FOR A PURPOSE-----SAFETY,,SAFETY...ALWAYS CHECK A MICROWAVE WITH THE POWER CORD REMOVED---YOUR MESSIN WITH A RF VOLTAGE THAT WILL KILL YOU!!!! UNPLUG,,UNPLUG,,,UNPLUG
TRY TO CHECK THE FOLLOWING...SINCE YOU HAVE THE COVER OFF,,LOOK AT THE DOOR LATCHES WHEN YOU CLOSE THE DOOR AND MAKE SURE THEY MAKE CONTACT ON THE DOOR SWITCHES,,3 OF THEM,,,--AN OHM METER IS THE TRICK FOR THIS - SOMETIMES YOU CAN SEE PLASTIC BROKEN ON THE SWITCH ITSELF...ALSO LOOK AT THE COMPLETE SWITCH HARNESS (CHECK FOR BROKEN PLASTIC PIECES) THAT HOLD THE SAFETY SWITCHES...THE MIDDLE SWITCH (MONITOR SWITCH) CLOSES WHEN YOU "OPEN" THE DOOR,,YES "OPEN "THE DOOR AND IT WILL BLOW THE MAIN FUSE..IF IT'S SHORTED.
THERMAL PROTECTORS RARELY GO BAD--IF YOU HAVE A PROBLEM WHERE IT TAKES 25 MINUTES TO COOK A BAKE" POTATOE"--JUST LIKE THE VICE PRESIDENT--THAT'S A THERMAL PROTECTOR..
PLEASE BE CAREFULLLLLL TUNICA
Oct 18, 2008 | GE Advantium SCA1000H Convection /...
Repair or replace?
MICROWAVES ARE MADE TO BLOW THE FUSE IF THERE IS A POSSIBLY OF DANGER--THAT'S A GOOD THING...SAFTY SWITCHES ARE MADE TO CLOSE(SOME UN-CLOSE) WHEN THE DOOR IS OPEN AND SHUT AND IT SOUNDS LIKE YOU DO HAVE A LITTLE DOOR PROBLEM---THE REPAIR SHOULD BE FIXABLE AND MAYBE REASONABLE,,MY GUESS COST-WISE ,,,75.00,,OF COURSE ,IT ALL DEPENDS ON THE SERVICE COMPANY--TRY AN INDEPENDANT SERVICER (NOT SEARS,ETC) GOOD LUCK TUNICA
Jun 10, 2008 | GE Advantium SCA1000H Convection /...
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Have to Slam Door to get it to work - Advantium 120
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 26, 2007 | GE Advantium SCA1000H Convection /...
Light is out
If the owner's manual does not address it, then it is probably not meant to be replaced by a non-professional.
If it is not accessable by a panel hidden by the vent grille, then the oven will have to come down out of the wall so you can remove the outer wrapper.
Nov 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000H Convection / Microwave Oven Logo
50 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
