Question about Microwave Ovens
Whirlpool OTR microwave no oven 'fan'
Our whirlpool OTR microwave MH7110XBQ shuts down.  The item being heated gets very hot very quickly, and there is no "fan" noise when the microwave oven is on.  You can hear the microwave tube operating, but it seems like the fan that circulates the microwave/heat is nonfunctioning.
We were able to tap on the keyboard, which would restart the "fan" noise,as if there was a loose connection behind the keypad, but now the oven just hums and the microwave shuts down after a few moments.
All other functions:  clock, light, exhaust fan, etc work normally.
Can this be easily repaired, or should we start shopping for a replacement?
  • Pat Eichers Dec 13, 2008
    I appreciate your response and I was ready to get the M/W repaired...however I could not find anyone who repairs microwaves around town....ended up buying a new unit.
    Thanks again for taking the time to try and help.
  • 50 Answers
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Posted on Oct 30, 2008
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
My microwave has no power at all
my mircro is MH7110XBQ-2 has no power. how do i get to the fuse is is built in over stove
help
toni
Oct 24, 2010 | Whirlpool MH7140XF Microwave Oven
Whirlpool microwave fan spontaneously came on
some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Jan 30, 2010 | Whirlpool MH7130XE Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
Whirlpool microwave oven
I have a nice PDF version of the technical sheet from a model MH1150, which should be similar. It's here:
http://www.microwavedisplay.com/whirlpool_mh1150xmq-0_wiring.pdf
Looking at that, I would say the fan relay "on/off" is stuck.
If your shop doesn't do board-level repair, we do it for $39.95 nationwide. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you'd like to discuss this further, please e-mail or call me via that link.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 18, 2008 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
174 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
