The monitor keeps going to sleep mode when you turn the computer. this just started
  • 1 more comment
  • Anonymous Mar 04, 2009
    Same problem, the second I turn the monitor on it says it's going to sleep, turns black, then nothing. I've tried totally disconnecting it, or starting it when it's connected to power but not the computer. If I disconnect from the computer it says to check the video cable, so I know it's getting SOMETHING, but then it goes to sleep after about 5 seconds. I can't pull up the monitor menu by pushing the button.
  • davidwell45 Apr 14, 2009
    I have the same problem but you can't go to the control panel because thr monitor won't come on for me to see where I at it turns on and gooes to sleep and you can't get it back on so if it don't wake up what can you do?
  • Anonymous May 15, 2009
    Your solution does not help us because we are unable to see ANYTHING on screen, thus rendering incabable of clicking the START button and so on...got anything else for us?
    Scholar:
  • 195 Answers
Well Pebbles lets try this and see. Click on your start button down there, then go to Control Panel and Click that.When Control Panel opens Click on Appearance & Themes, Click on Display and then Screen Saver tab. Down at the bottom is the Monitor Power button, Click that. Now there are tabs at the top, go to the Hibernate Tab and Click that, Now Clear the Hibernation Box, now go back up to the tabs and go to Advanced Tab and clear both option boxes. Okay now go to the Power Schemes Tab and clicik the blue arrow, scroll up and down till you see the never box and Click it, Make sure that it is Marked. Now your Monitor will never turn off until you turn it off on the Monitor itself. Now do the same thing for the Hard Disk Turn off, Click Never. And now your at System Standby, Click Never also. Click OK, and now your back at Display Properties. Here you can change your Screen Saver or Desk Top Background if you want to. Click OK when your done and your Done. Let me know if that helped and don't forget to rate my help, Good or Bad. Good Luck.
Posted on Oct 30, 2008
How can i keep the monitor from going to sleep mode while working?
in start-up menue, go to control panel/ hardware/power options, and change your power plan, change settings for monitor and computer to 'never', this will give you control over when it shuts down or sleeps
Jun 23, 2012 | Gateway Computers & Internet
When my computer goes into sleep mode and the monitor goes off i have to keep turning the monitor on and off by the power button on the monitor to get it to come on. I hear a static sound and the screen...
Assuming you are using a windows operating system, go to the control panel under the start button. Find power settings and turn off hibernation mode. Sleep mode should be ok. Additionally, on the monitor, find the menu button that pulls up the OSD (on screen display) and see if there is a ECO mode or power saver mode and turn it off as well. Good Luck.
Nov 03, 2017 | ViewSonic VG2021m LCD Monitor
My LCD Computer monitor keeps going into sleep mode everytime I turn on my computer, Is ther some way to get it out of sleep mode ? Re: 25" LCD Color Display Model # TSS-25m9 Serial # TS25093943
when pc starts hit alt and f4 then select an option from drop down menu by cliking on little v sign on right of box the option that should be there is sleep select shutdown then reboot it might work if not try same steps in safety mode by pressing f8 on first screen when pc starts select safety mode then try those steps again might help
Sep 23, 2010 | Computers & Internet
Monitor keeps going into sleep mode and it won't turn on so i can use it.
Monitors go to SLEEP mode when there is no computer signal coming into them. As soon as a computer signal reaches the monitor, it will automatically wake up and show the images in the screen.
Mar 27, 2010 | HP Compaq FP5315 15" LCD Monitor
Hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Mar 17, 2010 | Computers & Internet
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor keeps going to sleep
In windows click start, control panel, power options. On the first page"when the computer is plugged in" turn monitor off NEVER on the hibernate tab uncheck enable hibernation if checked, also disable sleep mode
May 12, 2009 | Computers & Internet
Computer asleep
I have to keep my pc in safemode now as mine is also in constant sleep mode and I can not get it out, It is the only way it will load up! :-(
Apr 09, 2009 | HP vs15 15"LCD Flat Panel Monitor
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
363 people viewed this question
David Payne
David Payne
