Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv shuts off for no reason
While watching tv, it suddenly shuts off. I have to wait a few minutes before I can turn it back on.
  • 927 Answers
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Nov 03, 2008
Harmon karmon sb15 soundbar sound shuts off
A capacitor on the power board has blown. Take it to a shop or warranty replace if available
Apr 12, 2014 | Harman Kardon SB 16 Main / Stereo Speaker
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
My TV will shut off for no reason while it is playing. Is there a reason for this?
I have had the same problem. There is a switch on the back of the tv near the power supply outlet. Try turning the switch and wait a few minutes then turn the switch back on or you can detach the power cord for a few minutes and turn it back on. This has happened to me for the last year and that would work but now it is happening and I can't get it to come back on at all. Anyone have any ideas?????
Dec 15, 2010 | Olevia 237T 37 in. LCD TV
I was watching the TV when it suddenly turned off. The audio fom the cable channel was still running on the independent surround audio system and I could change channels on the cable box. The power light...
Your partial resonance power supply IC with IGBT switch is bad. You will have to have tech replace it for about $50.00. The reason why your audio system still runs is because it is not part of your tv.
Sep 04, 2010 | Toshiba Televison & Video
Sony Vaio will not turn on
plz check the powersupply unit , ram
Jun 22, 2009 | Sony VAIO PCG-K23 Notebook
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Tv is going crazy!
This is a scrambled function processor and it would need to be re flashed by an rca service technician to fix this problem.
Nov 06, 2007 | RCA TruFlat 27F520T 27" TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
