Question about Maytag Kitchen Ranges
Nothing on display unable to turn on oven
Wife reported hearing a crackining sound then oven display went dark except for a single red light clock came back on momentarely and oven was beeping I turned off the power to the oven then turned it back on now there is nothing on at all on the display.
  • cepterjockey Oct 30, 2008
    is it something that can be replaced or do i need a whole new board and what would it look like?
    latest problem clue the clock on the oven came back on this morning but none of the buttons do anything
Its called a thermal fuse that goes right to the board. depending on the model
Posted on Oct 30, 2008
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after...
if the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
Feb 06, 2018 | Maytag MEW5527B Electric Single Oven
Bought used ge spectra range had to change the power cord to 3 prong to fit outlet--now nothing works except light when turning burners on and clock
Did you hear a "pop" or smell like something was burning? Sounds like old oven could have been 3 phase, and you new oven single phase, Check the power requirements for oven and see what kind of power you are supplying it with.
Mar 30, 2010 | GE Spectra JBP78 Electric Kitchen Range
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Kitchen Ranges Logo
221 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
