Question about Cell Phones
Replacing the charging connector plug - Cell Phones
    Brigadier General:
  • 7,752 Answers
You will need to have a technician replace that for you
Posted on Oct 30, 2008
On my 15in compaq how long should a fully charged battery last
A microswitch at the connection (where cord connects to laptop) is failed - this will need to be replaced, unfortunately, this requires nearly full disassembly of the laptop to get to the connector, and the whole connector has to be replaced. On one (of two) motherboards used in this model, it will require part to be soldered to remove, and soldered back on... the other it's a smallish board that unplugs from the main board.
May 30, 2014 | Compaq Presario V3010US Notebook PC -...
Plugged in not charging and continuously battery is not charging.
I had a Dell laptop that would not charge. I replaced the power pack and it worked for a while, but the problem came back. So I tried wiggling the connector at the computer when plugged in and it started to charge. Dell said that the connection on the mother board was loose or worn and needed a technician to fix. I taped the connector in place so that it charged. However, first use a volt/ohm meter to check that indeed the voltage output at the connector that goes into the computer. Look on the power pack for the output voltage and make sure it is delivering what it says it is supposed to be. Just be aware that the output voltage is DC not AC so set the meter to read DC Volts. Hope this helps.
Sep 13, 2013 | Dell Vostro 1014 Notebook
The remotes for my Viiper 5501 won't charge
There was an issue with these remotes when first manufactured. Try this, when initially charging the remote; plug the charger into the outlet then, plug it into the remote; remove, plug it in, remove; continue. It should take approximately six times before the remote says "charge" in the screen. If you repeat the process and the remote does not "wake up", replace it.
Jul 15, 2012 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
Garmin will not take a charge
Are you using the car charger adapter plug? If so the plug may have a blown fuse... I would unscrwew the silver end of plug and check fuse ...its spring loaded so be careful...
If the fuse is good try plugging the unit into your computer with the usb connector to see if it charges .... its a slow charge so may take a few hours to fully charge
It fuse is good and unit takes a usb charge the car plug needs replacing
Oct 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Good evening sir, I have yamaha R1 bike. in bike yesterday battery discharge than charge the battery. today bike start and running but after .5 miles bike is stop running, self is not running and battery...
1998 to 2002 have problem with plug to voltage regulator/rectifier which is under seat. connectors in plug overheat and bike stops charging the battery. you will see if connectors have been hot and will need to be replaced if they have.
once replaced check bike charging with multimeter at battery,should make 13.5 - to 14.5 volts just above idle. if not will need to test stator and regulator.
Aug 11, 2010 | Yamaha YZF-R1 Motorcycles
My Acer Extensa has a loose DC connector. The battery doesn't charge anymore. A new battery has been tried with the same result...the battery will not charge. The light on the AC adapter comes on when its...
You can just have the power plug replaced. Cheap enough and easy to do. Although if you take it to a shop they will charge you a fortune to do it
The part will cost no more than £15.00
May 21, 2010 | Acer Extensa 5420-5687 Notebook
Wont charge
How long have you had your iPod nano? It could be that charging jack the connector on the nano or the battery. When plugged in to a power source do you see the charging indicator in the upper right corner of the screen? If it's there and showing the lightning bolt charging or if you have noticed a decrease in the battery life or it's most likely the battery.
If this is a sudden problem it's the jack or connector. All you can do is attempt to charge it with another method. You really need to get a separate charging cord and plug and test it on your nano. If takes a charge your going to have to replace your cord. If not it's likely that the connector on the nano has been damaged. There are places you can send it for repair.
Hope this helps.
Nov 11, 2009 | Apple iPod nano 2nd Generation MP3 Player
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
Battery power died and the power cord will not charge or trun on the computer
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
The adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 07, 2009 | HP Compaq nx7400 Notebook
Cell Phones Logo
143 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
