Question about Toshiba 61HX70 61" Rear Projection Television
Toshiba model 61HX70 convergence issue
Hi everyone and THANK YOU in advance for any help you can provide, I have a Toshiba 61 RPTV (model 61HX70 bought new 4-01). I purchased a 5 year extended warranty just in case and as it turns out I really needed it. In 7-03 the TV started having convergence issues and the place that I purchased the unit from sent out a repair person he replaced - 2 IC 23905094 ? convergence IC?s? (the part # is STK392-110) - DCU PCB 23785122 'picture convergence board' This SAME issue came back about 3 weeks ago and since it is out of ?extended warranty? Toshiba will not work with me or help in offsetting the cost. Needless to say, I will not purchase another Toshiba TV as it seems 2 of the same issue in 5 years seems a little excessive. Anyway, I have been reading the forums and this seems to be a very common issue. I ordered 2 IC?s from Panasonic part # is C5AA00000203 (STK392-110). I received these IC?s, installed them and the convergence issue has been fixed, BUT The issue I have now is that the RED appears to be gone from the picture. Any help / suggestions to fix the lack of RED from the picture from the forum would be VERY much appreciated. Thanks again, m b
  • dpmad Aug 09, 2008
    Having the same problem, Red convergence is bad then gone all together, no red, picture is still sharp and bright in all corners, just no red. What parts do I need?
    Scholar:
  • 150 Answers
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Posted on Aug 05, 2007
I'm having the same problem where the red if out of line and will not calibrate. Which board controls this? Thanks for any help
Posted on Jan 15, 2008
SOURCE:
Audio but No Picture!
Unless you are absolutlyey sure that the value is correct on the resistor replacement I would put the original back in if it still checks good. I could not get you a Service Manual, but I do have a nice trouble shooting guide that I can send you. I just need your e mail.
Apr 16, 2012 | Toshiba 61HX70 61" Rear Projection...
Tip
Toshiba 61HX70 Service Manual Download
Download Toshiba 61HX70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 61HX70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 61HX70 Manual Download
on May 10, 2010 | Toshiba 61HX70 61" Rear Projection...
Tip
Download Toshiba 61HX70 Projection Television Manual
Have you misplaced your Toshiba 61HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television instructions.
I hope that helps.
Hi, I have Toshiba 61HX70. There is no picture. What coudl be the problem?
Take a look at my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help solving this problem.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 06, 2011 | Toshiba 61HX70 61" Rear Projection...
A friend bumped into my Toshiba 61HX70. Now the
Convergence is off. A tech can help resolve the issue.
May 27, 2010 | Toshiba 61HX70 61" Rear Projection...
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 61HX70 61" Rear Projection...
No picture is it the bulb and is this hard to change?
You DO NOT have just a bulb in your set. You have the older style Projection TV with three picture tubes. It's a good possibility that you have a convergence issue that has blanked the raster and therefore you will not see a picture until the error is corrected. Have it looked at by a qualified technician.
Sep 11, 2009 | Toshiba 61HX70 61" Rear Projection...
Where is the hard reset located
This is not a problem that a "reset" will resolve. There is a problem with the convergence circuit. It may be as simple as poor solder connections on the convergence ICs. If you can solder, you can fix this yourself. Please let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Feb 05, 2009 | Toshiba 61HX70 61" Rear Projection...
Picture red and green not lining up on my Toshiba 61HX70
Repair will require technical and mechanical skills.The red convergence IC will need replacement,which will require the chassis to be removed.After IC change,alignment in the servicer menu may be needed.Go slow--Remember, above all else,do no harm.You have a great tv,so my suggestion is get a senior tech on this one.
Sep 26, 2007 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61HX70 61" Rear Projection Television Logo
704 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
