Question about Samsung SyncMaster 193V 19" Flat Panel LCD Monitor
Monitor gets power but no picture
I got this monitor from work, they were throwing it out cause the video isn't working. The monitor still gets power and the light comes on, but the screen is blank. Just wondering if it's something I can fix. Any suggestion would help. Thanks!
  • Anonymous Mar 28, 2009
    I got the same problem, I tried all of the solutions written here and still nothing, If I press the menu button down I get TEST GOOD in the corner of the screen. Any other ideas?
  • 749 Answers
Check the cable connections
reconnect them. if nothing happens try hooking it up on a different computer.
if picture does appear still, check the video card of your computer, it could have been damage.
Posted on Oct 30, 2008
I have a pair of Samsung Monitors 2232 (manufactured in July and August of 2007). They both recently developed problems and died. I searched and found replacement capacitor packages for $10 per monitor, popped of the back, soldered them in, and they are working like a charm now. I am writing this from those previously black monitors. You can find the repair packages on Amazon, eBay, etc. I got mine from LCD Alternatives (eBay was the least expensive alternative). It took about 30 minutes each but my sons now know how to solder. I ordered an inexpensive 60 watt soldering iron from them as well because the Samsung solder needs a really hot iron.
monitor gets power but no picture - monitor-gets-power-but-no-picture-lhuvdi0emy4qxxtp3t0a5k4a-4-0.jpg
Posted on Mar 05, 2015
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Nov 02, 2012 | Hanns.G Corporation HW191D 19" LCD Monitor
Tv has sound but no picture
This is almost certainly a problem with the backlight power supply, not the ac adapter. If the backlight isn't working, you will see nothing on the screen.
Aug 30, 2012 | Insignia NS-LCD15 15" LCD TV flat monitor...
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Amber (ON) light blinks but I have no picture (screen is black & no sound)
Good day! Have you try any monitor on you pc? Try it first.. And check the video resolution of ur pc..
Nov 21, 2011 | Scanport GL-1920S 19" Flat Panel LCD...
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
The orange light continuously blinks on my NEC MultiSync FE990. I'm thinking it might possibly be the video cable which is attached to the monitor. If this sounds like the problem, how would I...
It could either be the Monitor has gone bad, the video card in your tower, or the cable connecting the two, the orange light signifies that the system is not getting the signal from the tower. Try replacing the VGA cable, if this is not an option try using the monitor on a different computer, if still no picture then the monitor is no good, if you get a picture try a second monitor with your desktop. If you get no picture then it is time for a new motherboard or graphics card. As far as replacing the cable if it is one piece with the monitor, it isn't recommended unless you a very comfortable opening the monitor up, in which case you risk causing more damage.
Aug 01, 2011 | NEC-Mitsubishi NEC Display Solutions...
My samsung syncmaster 203b, the screen has just gone black with no picture but the power light is still on, i unplugged it and swapped it with my other samsung syncmaster monitor which is working but the...
This model is a great one and well worth repairing. The display problem you are having is caused by bad capacitors on the power supply board. To repair the unit you will need to replace 6 capacitors and one fuse on the board, this is very easy to do, it just requires a little soldering. Here is a picture of the power supply board with the capacitors and the fuse circled and here is a link to additional information on the capacitors needed.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Aug 12, 2010 | Samsung SyncMaster 203B LCD Monitor
My screen suddenly gets distorted.
Test your laptop by connecting its video ouput (base of the computer at the back) to a known working monitor. Then power on the laptop and see if the known working monitor behaves the same way your laptop's monitor does. That will narrow down the possible causes.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Samsung SyncMaster 193V 19" Flat Panel LCD Monitor Logo
385 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
