Question about E-Machines eMachines Desktop PC
E-machine model t3302
I want to install a DVD burner, how do I open the PC.
Do you take off the side first or the front. Is there a latch somewhere?
    Problem Solver:
  • 15 Answers
You shouldnt have to take off the front. Safety first make sure it is unpluged and you should have a ground strap or what i do is hold the chassis the whole time Im working on it so static electricity dosent fry anything.if your just taking the old one out and putting a new one in you will see how it is connected.if your puttin a second one in you will have to make sure you have enough power cords and drive outlets to hook up a second one.
Posted on Oct 30, 2008
How to remove hard drive from t3302
open case locate the hard drive unplug cabled unscrew it side it out and reverse to install
May 10, 2014 | E-Machines eMachines T3830 PC Desktop
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Any instructions on how to install the LG(GSA4167B)DVD RW super multi
turn off PC > open left side panel of the PC casing > remove drive slot in front of the case to insert the new one > You find two connectors, the data cable (IDE or SATA) and the power cable (MOLEX or SATA connector), you need to fix the proper data cable one end to the motherboard and the other one to the Drive Connect the proper power cable from the Power Supply Unit then you are good to go :) good luck
Jan 31, 2011 | LG (GSA4167BB) DVD RW Dual Layer Burner
Where does the video card go in a t3302 model emachine?
This particular model have AGP expansion slot located on motherboard, as this is rather obsolete computer, I am not sure if this is financially viable solution.
You will need phillips screwdriver.
To proceed with upgrade:
1. Switch off computer,
2. Remove power cord and monitor cord, if you want, you can disconect all remaining cords as well, but only if you are moving computer elsewhere.
3. Remove two thumbscrews holding left side (grill) panel, then slide it back and lift off
4. AGP slot is located below processor, just above white PCI slots, it is offset slightly towards front of the computer. If there is little screen mounted in first hole, remove it, depending how it is mounted by either, removing of the screw, or breaking it from the case.
5. Orient your card and insert it firmly in AGP slot, card should fit snuggly without bending or excessive force. Use screw to mount it to the back of the case frame.
6. Connect all cables, monitor cable to new installed video card, start your computer and check if there is display, if you have BIOS display, switch off computer, you installed your video card correctly.
7. Replace side moving it in reverse to removal, hung it first on the top and then slide forward, secure it back with thumbscrews.
8. Start back your computer
9. Install video drivers and setup your display to desired resolution.
Enjoy!
If you need manuals and settings for this model, these are availbale at this acer site:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3302
Aug 06, 2010 | E-Machines T3302 PC Desktop
While intalling new hardware I pulled out the front panel (hdd led power Sw & Power led) i saw pin layout as ::::. Do I connect to these pins? If you have a diagram it would make it much easer. Could...
eMachines T3302 desktop computer?
According to my information it uses an FIC K8M-800M motherboard.
(First International Computer, Inc.)
(Looking in-between the brown AGP expansion slot, and the first white PCI slot, you should see K8M-800)
http://www.fic.com.tw/product/motherboard/AMD/ficimages/k8m-800m.jpg
IF, my information is correct about the motherboard used, I would like you to download the Motherboard Manual for it.
(I haven't worked on one of these puppies in my shop yet, so I don't know if the eMachines T3302 uses an FIC K8M-800M mobo. MOtherBOard)
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Under the Filename heading in the Middle, scroll down, and Left-click on - FIC K8M-800M
This is a Zip file. (Compressed file for easier transfer)
Watch the download progress bar, and let the file download all the way. ( 1 minute, 45 seconds for me)
Where the file will go;
Windows XP:
It will go to your My Documents folder (Start > My Documents), or to a subfolder in My Documents. Downloads.
Or it may go directly to your desktop screen.
(Yellow folder icon, with a zipper in the middle. K8M-800_manual
underneath)
When you see the file, Double-click on it.
Go up to the left side of the screen.
Left click on - Extract All Files
Left-click on Next, and Finish.
In the small window left-click on the PDF icon with K8M-800_manual.
Barring you cannot download, or open this Zip file.
Orient the motherboard in your view, so we are both looking at it the same way.
Processor to the top.
Ram Memory slots to the right.
Bottom right corner has the CMOS battery, and the Front Panel header is to the left of the battery.
Under the Front Panel header it has F-PNL
Your pinout of the Front Panel header is upside down.
There are 5 pins across the top.
There are 4 pins across the bottom.
The Top pins are numbered Odd.
The Bottom pins are numbered Evenly.
The numbering starts from the Right side of the motherboard, (CMOS Battery side), going towards the Left.
Top row, going from Right to Left,
1, 3, 5, 7, and 9
Bottom row, going from Right to Left,
2, 4, 6, and 8. (There is No pin 10)
A) Pins 1 and 3 are for the HDD LED. (Harddrive activity light)
B) Pins 5 and 7 are for the Reset switch.
C) Pins 2 and 4 are for the Power On light. (Indicates power is on)
D) Pins 6 and 8 are for the Power On switch. (Turns the computer on)
Jun 24, 2010 | E-Machines T3302 PC Desktop
I have a Sony all in one computer and today I was using my DVD burner and it will not open
DId you have a DVD/CD installed - if so take a paper clip and untwist it On the front of the cd tray in the middle section you should see a small HOLE MAKE SURE THE MACHINE IS SWITCHED OFF
push the paperclip into the hole and a slight pressure should unclip the drawer - remove the DVD/CD
if you dont have any CD/DVD installed are there any lights on the front ?
Mar 19, 2010 | Sony Computers & Internet
My rewriter is broken drawer ha been snapped off
This is Dell Support>Dell Dimension E520 Desktop PC>Service Manual,
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/index.htm
I invite you to left-click on - Specifications
Scroll down to the heading - Drives
Available devices - 4 Serial ATA drives - CD/DVD drive.
Serial ATA. Looks kind of confusing, huh?
= SATA
IDE has been changed to PATA.
(Integrated Drive Electronics)
It has been felt that there would be less confusion this way.
PATA = Parallel ATA
SATA = Serial ATA
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
The Dell Dimension E520 Desktop PC comes with a dual layer DVD burner, and a DVD drive.
(DVD burner will have DVD-R/W or R/RW on the front usually)
You need a SATA DVD R/RW drive.
Myself I use Lite-On optical drives.
Why?
Cheap in price, high in quality. I have one I have been using for over 3 years, with no problems. Price was around $35 US.
Not advertising for Lite-On.
It's a dual layer, DVD combo drive. Burns CD's, and DVD's. Has the HP LightScribe technology. If I use the HP disks for LightScribe, I can make labels for the disks, or burn a label right on the middle of the disk itself.
TIP: Everyone looks for a f-a-s-t burner! The Lite-On I have is Fast. You Do Not want to burn disks in a fast mode.
Better quality of copying, or recording is done at a slower speed.
Should your optical drive not come with burner software, I recommend Infra Recorder.
It's Free, and works Very well.
(I like it better than Nero)
1) Computer unplugged from power
2) Open the computer case side panel (Side panel release latch is on top, at the rear. In the Service Manua,l you can click on Removing and Installing Parts. Scroll down to Removing the Computer Cover)
3) TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Your body carries Static. Static will fry out computer hardware components. Computer unplugged from power you are safe. TOUCH the metal frame, your computer is safe)
4) Removing and replacing an optical drive.
In Removing and Replacing Parts, you can scroll down the page for details.
(Approximately half way down. Under the heading Removing the Drive Panel)
I find the instructions 'Less Than'
The Drive Panel is the Front Cover.
The Front Cover has to be removed, in order to remove either optical drive.
This is done by releasing the blue Slide Latch.
The blue plastic slide, on the side of the optical drive bays.
The plastic tabs are depressed, and the blue plastic slide goes towards the rear of the computer.
This allows the optical drive you wish to remove, to slide forward, and out.
I slide the drive I want forward a little, so that I can get my big hands on those cables.
You will have a 7-pin Data cable, and a 15-pin power cable to remove.
Installation is the reverse of these steps.
Jan 11, 2010 | Dell Dimension E520 PC Desktop
MFATXPNT ESX 500S GATEWAY model above. Want to open the case and install 2 more memory boards. How do I open this case? Ralph
On my model, there is a broad recessed area on the top of the case.
On the left-hand side of this area (as you face the front), there is a 3-inch-wide, grooved-surfaced latch that must be pressed inward (to your left) to free the left panel. If you are facing the left side of the unit, pressing this latch inward by grabbing the top of the panel as if you were going to pull it off by force naturally presses in the latch, opening the case.
If you're not seeing the latch, note that the top half of the front can be covered by a rotating cover that covers the drive bays. When it is not covering the front, this rotating cover flips up and around, coming to rest on the top of the unit in the broad recessed area.
When this cover is flipped up and stored at the top of the unit, the case latch is hidden and not pressable. Flip the cover back down so that it's covering the drives, and you're good to go.
Nov 04, 2009 | Gateway GT5220 PC Desktop
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
E-Machines eMachines Desktop PC Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
