Question about Intel Motherboard
Replacing mb hdd, can i still reactivate xp pro?
my mb has fried and my hdd is not real good either, running xp pro wichwas activated using the current setup, if i replace the mb and the hddcan i still activate the pc with the afore mentioned items installed ?
  • 781 Answers
You should be able to
May have to phone microsoft to do so if you do have pen and paper handy to write numbers (a lot of them down)
Posted on Oct 30, 2008
How to use the Hard Disk for Super MB STAR, anything i can do to learn
Hard Disk for Super MB STAR 2011.09 External HDD Format
Hard Disk for Super MB STAR 2011.09 external HDD Format is software for Super MB STAR, software version 2011.09. It works together with Super MB Star. It can used on computer with windows xp computer. Your computer need have serial port.. It is only one hard disk and it is DELL D630 format, so it can used on computer with windows xp computer. Your computer need have serial port.
2. It works together with super mb star and it has usb key in the package.
3. Software version is 2011.09. Update on www.supermbstar.com
Package including:
1pc x Mobile HDD with USB Cable
1pc x USB KEY
1pc x Verification Letter with Password inside
Contact information:
Skype : greebid6
UOBD2.COM
MSN: chinauobd2@gmail.com
sales@uobd2.com
E-mail: chinauobd2@gmail.com If any problems,pls feel free to contact us.
How to purchase on UOBD2.COM?
hope it helps
Apr 20, 2012 | Computers & Internet
I need a user manual for a xn900
contact your dealer for the manual they will have it. also what do you need the manual for , just on how to set it up? basically you just use the usb (or serial interface) and run the calibration wizard.
Mar 13, 2011 | Microsoft 12.1" Touch Screen Terminal -...
Cannot install ANY Windows OS on Aspire One AOA150
I have run into several issues with installing the OS with a USB on the Acers....I got around it by using an external dvd drive. I picked one up for around 45 bucks on ebay....booted off that and the install went through without incident.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Os istallation problem
Hi Prashant
This will apply is you are using a SATA drive and are attempting to install Windows XP:
In the box your motherboard came in, there should be a 1.44Mb floppy disk (Also called a stiffy). This will have the driver for XP to be able to read your SATA controller. If you do not have this "stiffy", either contact the hardware manufacturer or check their website for a download.
When Windows XP setup starts, and you are greeted with the blue screen, press the "F6" button when prompted to do so - to make XP setup allow you to install a 3rd party driver SCSI or RAID controlled. This you have to do within a few seconds of setup starting, so make sure to look carefully. The message will appear in the bottom of the screen.
This applies for IDE / ATA HDD:
Ensure that the HDD is being properly picked up by the BIOS. If not, ensure that all connections are good. If they are, test with another, known good, HDD to check whether your HDD is not maybe at fault.
Jan 07, 2009 | Tyan Tiger K8WE (S2877ANRF) Dual Opteron/...
Vista drivers
Go to the Gigabyte website and check for Vista drivers based on the motherboard model #. If not available there use a program like aida32 or fresh diagnostics to identify the ethernet make and model and go to that manufacturer's site for the Vista driver. You may also be able to just explore the cd that came with the motherboard to find the ethernet driver folder and see if a Vista driver is there and manually install it without using the normal gui install interface like in XP.
May 10, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
