Question about Sony CDX-F7005X CD Player
Humming and static and not working
We bought a used car that came with this system. It worked fine for a while; then the car was parked for a few days without being driven, and the battery wore down and we couldn't start the car. We put in a brandnew battery which also wore out after a couple of days. Someone told us that the stereo is sucking the power out of the battery, so we took out the fuse that connects the radio. Then it didn't wear down the battery any more, and we've been driving the car without the fuse, and -- without any radio. We would LOVE to get the radio (and CD) to play again -- especially since the car was given to another one of our children. We put in a new fuse, and now the car (or the radio) hums really loud after it's turned off, and after the key has been taken out of the ignition. We can press the "off" button on the radio, but that doesn't solve anything. It just hums (loudly) for a minute or so. There is no way to stop it. Of course, we're afraid it's going to wear down the battery again. What can we do to fix this? For the first few months, the car ran fine with the radio on or off. We should be able to re-create that, right? I should also mention that this car has HUGE speakers, and another fuse for the speaker system. But we haven't even put in the fuse for the speakers yet. We should still get sound through the regular speakers. Is there a certain size fuse that we need? Did we perhaps get the wrong one? Have you ever heard of anything like this? That a radio wears down a battery? Any help would be greatly appreciated!!! Angela
Re: Humming and static and not working - Sony CDX-F7005X CD Player Car Audio Receivers
Put the cd player and amp on a switch
Posted on Nov 09, 2007
Try turning both of the amplifiers knobs down a little it should say gain or power or maybe the frequency knob like hz
Posted on Jun 15, 2007
  • 62 Answers
If the deck is not turning off i would say it is wired incorrectly. There are two types of power inputs on the deck... One that only gives power to the radio when key is on, and one that constantly has power (to save your clock and settings) If the radio is not turning off It sounds like the two wires are connected directly to the 12volt source bypassing the key altogether.
Posted on Mar 25, 2007
  • 72 Answers
Angela You need to keep the system rewiried or at least checked out by a professional. It sound to me like the amplifier in the back of the car is staying on this would explain the battery problems and the hum. Sometimes when wiring in systems the amplifier will use the factory speakers in the car and will amplify the sound and you create a feedback loop. ( like putting a microphone in front of a speaker) If the amplifier is not on and the power cables are unhooked and you are getting this hum through just the radio. I would suspect a faulty radio. But I am guessing from what you described you have a miss wired stereo system.
Posted on Sep 09, 2006
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
0 characters
3 Points
You should check all the connections especially the radio for dust, rust, or any dirt. If that doesn't work then you need some kind of radio adapter to improve you signal.
Jan 19, 2013 | Car Audio Receivers
The unit worked fine for a long time. a few days ago i changed cds and when i put the cd in it sounds like it is spinning and then nothing and it ejects the cd..the radio still works on the unit. I just...
Some Panasonic stereo's don't like non shop bought, home burnt discs (they are recorded at a different level) so try new discs plus run a CD laser cleaner through your system.
Jul 12, 2011 | Panasonic CQ-C1101U CD Player
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
Niosy axilary input
Sounds like what you are experiencing is feedback. Go to any local audio store and ask for a ground loop isolator. It is in lehmens terms a noise filter. Basically it is a go between your device and input via RCA. See if this takes care of the problem. Good luck
Nov 14, 2008 | Alpine CDA-9855 CD Player
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
Sep 14, 2008 | Alpine CDA-9856 CD Player
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
Humming from speakers when CD player running
Yes, The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter. Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable. You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho. First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal. If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack. If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car. If you still have that hum it may be the spark plug wires but that sounds more like static than hum. You have a text book case of alternator hum... Hack
Jul 11, 2007 | Xtreme Sound WMS336 CD Player
Radio malfunction
There's definitely no code you can enter to fix this. Sony doesn't use anti-theft codes, and in brands that do, they don't work like you're describing. Either the unit is defective or the antenna has been disconnected.
Jun 02, 2007 | Sony CDX-M610 CD Player
Sony CDX-F7005X CD Player Logo
388 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
