Question about Garden
My echo260 and will not run right all new gaskets in carb willnot but25% on choke
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and clean with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 29, 2008
Doesn't get enough fuel to run without full choke
The choke doesn't give it more fuel.! It gives it less air. But your right that its not getting enough fuel. Check the fuel lines from the fuel filter to the carb. Make sure it has good compression as its the vacuum created by the downward stroke of the piston that draws the fuel/air mix in. Check and clean the carb, replace any fatigued diaphragms and gaskets in the carb.
Apr 27, 2016 | Weedeater Garden
Engine won't run unless choke is partially closed.
when the choke is partially closed there is extra vacuum created in the venturi of the carby that assists to help pull the fuel through the main jet and the idle circuit
it indicates that the main jet circuit still has a blockage or there is insufficient fuel getting to the carby ( vent problem)
it could be from a gasket or diaphragm blocking a vacuum port or the fibre block under the carby incorrectly fitted
Aug 14, 2015 | Garden
Ski-doo won't stay running or idle
sounds like it could be the air to fuel ratio. if it only want to run with the choke on. I would say to make sure all your nuts and bolts are tight and that you check the gaskets in between the carb and the motor. another thing you could do is get a can of starting fluid and spray it around the carb while the motor is running (do not spray it in the carb)if the idle changes or if it dies you need to replace gaskets.
Dec 19, 2013 | Motorcycles
Stihl ht70 will only run with the choke full on. New carb no help.
also make sure to clean out the spark arrester. it can cause back pressure and damage gaskets. also stops power..
Nov 17, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Just replaced the carb, fuel lines, filter and gasket that goes between the carb and cylinder wall. All brand new parts. I believe lines are connected correctly. Now the engine runs like it is on full...
I don't think it has anything to do with the high/low settings, but in case was the carb pre adjusted or did you adjust them yourself. Did you put the throttle cable in the right hole on the throttle plate if there is more than one. Check the idle speed screw (not the low needle) to make sure it is not causing this. Look to make sure the throttle butterfly is not binding in the open position or that the throttle cable itself is the culprit. Maybe your gasket moved when re-installing causing plate to stay open. I suggest removing carb and inspecting for any of these problems. Maybe there is something wrong with your new carb! I hope this helps out. Happy to answer any questions.
Dec 03, 2010 | Craftsman 25cc Gas Line Trimmer
Why does my mower shut off after I turn the choke off?
It sounds like you took the carb off the engine and did not replace the gasket or tore the gasket and it is sucking too much air. Also check to see if the carb and bracket ( if it has one ) are on straight.
Sep 12, 2009 | Mtd Garden
Poulan 3700 will not keep running when you open the choke.
The prob is at the base of the carb. Its sucking air. Be certain to install a new gasket, making sure the both services are very clean. And the mounting bolts tightened equally! Frankster016
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Home lite weed eater
the fuel rails inside the carb could be clogged, try cleaning with carb cleaner and blowing out the rails with compressed air. or the car may need replaced.
Nov 04, 2008 | Garden
Homelite hb 180 leaf blower
Changed all major gaskets: Cylinder to crankcase, case half, exhaust & carb. Now it runns right. The carb can be adjusted and the choke is full open when warmed up as it's supposed to be.
Gaskets ca be bought from Homelite directly at http://www.homelite.com/service_support/order_parts
Enter the model numbers & see the exploded views. Torque values are provided in the parts lists.
Nov 01, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
