My truck will idle fine without overheating, but as soon as you start driving it overheats to over 260 degrees. Already flushed the radiator, replaced the thermostat, drove without a thermostat and it still over heats. Also, the fan clutch doesn't appear to be slipping at all. Any suggestions?
SOURCE: 2004 dodge ram overheating
How hot are you talking? You checked your cooling fan? You know your water pump is good? Not loosing any anti-freeze anywhere?
SOURCE: 2002 VW Jetta Overheating
Stop driving the car asap, have it checked and fixed, otherwise you could be facing very expensive repair in the ery near future.
SOURCE: ford ranger truck overheating
I have had this happen with my ranger. Changed everything I could to try to fix the over heating. It turned out that I had a small leak in my head gasket and it was allowing exsaust gas to go into the cooling system witch was over pressurizing it. Also the air from the exsaust will heat up much faster than liquid making your thermostat to read hot and will not be able to blow hot air in the cab because there is no liquid going to the heater core. This happened to me when my blet came off and I tryed to make it home. If you had it over heat for a long peirod of time it may have ripped the head gasket.
SOURCE: Overheating fiat seicento
I hope you have managed to solve the radiator problem by now. Seicento seem to suffer from water flow blockage in the heater blower area. I recommend you check the piper behind the carburator and make sure water is flowing. Normally when these pipes are blocked, water will flow back to the expansion tank and start leaking through its cap. You can also open the small screw on the small pipe coming out from the back panel behind the carburator and see whetehr water flows. Also, if the water is heard grumbling when engine is switched off, it is highly likely that the water is not flowing through the heater unit. Hope this helps.
Cheers,
Andrew
Check your water pump and also sometimes a radiator flush is not good enough more than likely the radiator is blocked you have take to a radiator expert and have pulled apart and cleaned thoroughly
Overheating is caused by few possibilities .All needs to be checked inspected.I recommend you few help links to troubleshoot the issue.Click the link below:---
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Engine overheated then car will not start?
http://schematicsdiagram.blogspot.in/2012/02/engine-overheated-then-car-will-not.html-----
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Vehicle Is Overheating
http://technoanswers.blogspot.in/2012/07/vehicle-is-overheating.html
These will help.
Thanks.
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------This details will help.Thanks.
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
troubleshooting?
troubleshooting?
