Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Freezer is freezing up, then freezer and fridge warm up.
I removed the panel in back of the freezer and the coils are completely encased in ice. About two weeks ago had the same problem, I unplugged the unit and melted the ice. Fridge and freezer worked great for about two weeks. It seems like the defroster in not working. Coils underneath are clean. Ice maker works.
  • 943 Answers
Hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Posted on Oct 30, 2008
  • JAMES ASHWORTH
    JAMES ASHWORTH Jan 24, 2012
    Will this same problem cause the water dispenser to not work? I have the same problem. The freezer coils and back panel froze so I thawed them out. It started freezing normally then about two weeks later back panel is froze again, water won't dispense and the fridge isn't cooling like it should. Please help.
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
My Samsung SRL550DW keeps cutting out. If you turn the power off it restarts and works fine and then cuts out again after a few hours. Is this a main PCB problem. Prior to this happening the door chim
I have had the exact same issue and its not a samsung issue but any modern fridge with a defrost system in the freezer (fridge doesn't generally frost up as its not run at freezing temperatures.
You need to check a few things:
1. Clear the freezer draws out and clear any ice build up.
2. Be careful and unclip the first white plastic vent panel (hint: pull from the middle an inch or two then push the sides in so the tabs are pulled towards the middle and the panel pops out)
3. Unscrew and unclip the 2nd panel (holds the circulation fan) to view the freezer coils - you will need to unclip the power for the fan and the heating coil for the drip tray under the freezing coils.
4. This is where the issue usually is:
If the tray is full of ice then do the following. If not and you can poor water through the drain hole on the bottom, then the issue is a dead sensor or control board - seek professional advice or if your game, there are swap out kits you can buy.
So the drip tray is full of ice ? Unscrew the freezer coils from the back wall but DO NOT touch it any further in case you damage it. There should be some silver tape tape that holds the tray in place - remove it and then gently lift the coils up to allow the tray out. If its too full of ice, use a hair dryer or warm water to de-ice. Once the tray is out, defrost it completely and dry it - be careful not to damage the heating wires under the tray as this is used to deice it during a normal defrost cycle. Clear any remaining ice on the coils or along the back wall - Dry it well.
Usually the cause for the drip tray to freeze up is a blockage in the drain pipe that empties into the back of the fridge. Unscrew the back panel and you will see 2 soft plastic pipes drain water into a water tray. pull both off and clean/inspect. You will notice they pinch in the middle to stop air getting back in, but allows water to drip out. If they are blocked, they will back fill the internal drains and freeze, thus fooling the fridge into thinking it hasn't defrosted yet and not turning the compressor back on. (Since this ice is hidden at the back, it is the last to melt thus the freezer gets warmer waiting for the insulated ice near the drain to melt.
When I did my freezer, the water is dripping out slowly (it was cold) but once I removed the pipe, it emptied properly. inspection of the pipe showed dirt/insect blocking the pinched section of the pipe.
Reassemble the pieces in reverse order, ensuring the water was been dried with a cloth. My fridge/freezer hasn't skipped a beat since.
May 07, 2012 | Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
