My monitors green light stays on, but the screen will come on for a second then goes off, it keeps repeating this. I have seen a couple on e-bay with the same problem. any ideas?
I have the same issue also, my father in law took it apart and didn't see any bad solders. But once it get s a little warm after a minute or two it automatically shut off with the green light still showing. I can hit the power button to turn it back on, then it will stay on for about 2 seconds then go back the the black screen, like it's in sleep mode. Any help would be appreciated! Matt Muzik8799@aol.com
Comment by Guest, posted on Mar 02, 2008
When idle or if computer turned off, monitor turns black and although light is green, monitor flashes on momentarily then turns black again
Best Solution
posted on Dec 19, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
Saw this happen on a monitor before, opened it up, found cold solder joints (where the component leads were not soldered very well to the circuit board), fired my solder gun up, resoldered every suspicious looking joint and presto! Been working fine for over a year now. :-)
Was this solution helpful? Show your Appreciation by rating it:
