Question about Canon ZR100 Mini DV Digital Camcorder
Can't download video to macintosh from the canon zr100
HI - I plug into the DV port on camera with firewire to my mac.  nothing!  it doesn't seem to recognize it at all.  do I need a specific driver?  i cannot find a driver for macs anywhere.  Please help!  thanks
  • 4 more comments
  • catphotogal Oct 30, 2008
     I have a: Mac OSX Version 10.4.11
    1,25 GHz Power PC G4
    1 gB DDR SDRAM
    trying to use iDVD.
    any additional thoughts?
  • catphotogal Oct 31, 2008
    HI - i did all you said , hit refresh and this is what came up -
    FireWire Bus:
      Maximum Speed: Up to 400 Mb/sec
    the camera is on in playback mode and the mac still doesn't recognize it.  the firewire cable is brand new.  do I try a different cable?
    Hey - thanks so much!  you are so helpful!
    I have ilife'08 but i cannot run imovie.  it says i need a G5.
  • sempci Dec 19, 2008
    Hi! I connected my camcorder to my Mac but it isn't reading it. Alothough in the system profiler it does show up - but nothing is happening. Any suggestions?
  • Cee Jai Bernard
    Cee Jai Bernard May 11, 2010
    I've never tried to import video directly from a DV camcorder to iDvd, I'm not even sure you can. I would first try importing the video into iMovie.. then once it's there you can take the video from imovie and import it into iDVD.
    But before you do that, make sure your camcorder isn't connected then Click on the apple button in the top left hand corner of your screen, go to "about this mac", click on "more info". then on the left side of the window that pops up click on "FireWire".. to the right you should see something like "firewire bus....Maximum Speed: Up to 400 Mb/sec" Now connect the camcorder via FireWire and go back to that window and go to the menu "View" then click on "Refresh". At this point there should be a description of the camcorder in the area to the right.. if nothing changed, that means your computer is not communicating with the camcorder so the camcorder is either in the wrong mode, or the firewire cable is bad. Let me know what you find.
  • Cee Jai Bernard
    Hey, there is no easy way to tell you this but you're semi screwed. All DV camcorders use the same driver, which is why they're all plug and play. But for some reason some macs don't like certain canon products. My friend has this camera and i wanted to take some footage off of it, i tried on my main computer which is a powermac G5, it did not work. So i tried on my other Dual g4, didn't work, basically i tried on 6 macs and it only worked on two and they were both mac mini's One with a 1.6GHz solo and one with a Dual 1.83GHz Duo. I searched the internet for a solution and came up blank. Are you trying to use imovie or Final Cut? also what kind of mac do you have ?
  • 59 Answers
Unfortunately, it looks as if you may have one of the macs that just doesn't want to co-operate. If the FW cable is brand new, i highly doubt you've got a defective cable. After doing a Google search, Canon knows of this problem and hasn't offered any real support or a solution. I could only assume it's the camcorder and not the mac. Give me another day or so and I'll get back to ya, I'll see if I can borrow my friends camcorder and try to get it to work on one of my other macs.
In the meantime, try opening imovie , connect the camcorder while it's off, turn it on and set up imovie as if you were about to capture ntsc footage. Next play the tape in the camcorder and see if imovie recognizes it then.
Posted on Oct 31, 2008
I have a Panasonic PV-GS59 mini-dv camcorder- I shot some video and plugged the usb into my macbook pro. I tried every setting to on the camera to get the computer to read the video. Nothing works. The...
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
Jan 13, 2011 | Panasonic PV-GS59 Mini DV Digital...
I'm not able to install drivers for my sony mini DV DCR-TRV22E handycam on mac os.
The DCR-TRV22E Camcorder can be connected to the Macintosh Computer with the i.LINK (Firewire) cable. The Software supplied with the Camcorder is not compatible with the Macintosh Computer. Instead you've to use the Firewire cable for connecting the Camcorder to the Computer. You can use the iMovie Software for transferring the videos. You do not require any drivers from Sony, to transfer the video via i.LINK.
You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
Thanks for using FixYa.
We wish you a happy Christmas and NewYear!!
Dec 23, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
I have an acer 5740G laptop to which when i am connecting the MV 920 cannon cam corder through the camera's port in to the laptop's USB port, the laptop does not recognise this as an external removable...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. With desktop Windows PCs, you can fit an add-on Firewire interface card. This comes with a driver for the card. If your laptop doesn't have a Firewire socket, then you are probably stuck.
Nov 07, 2010 | Canon MV920 Mini DV Digital Camcorder
I have connected my canon xm2 to the computer via the usb cable but nothing is happening? how do i get my videos on the computer?
It looks like the USB port on this camera is used to transfer stills only. The camera has a DV port for a "Firewire" connection to stream video to a computer, but most PCs don't have such a port (Macs do). You can add Firewire ports to a PC using an add-on card. You will need a cable too. These things are available cheaply on eBay or Amazon.
The software needed and manuals for this camera are available for download from
this page
Oct 20, 2010 | Canon XM2 Mini DV Digital Camcorder
Camcorder is a Canon Mini DV ZR100 in very good shape. While recording with an AV plug into two DVD recorders and the firewire plug into a Macbook Pro, the picture seemed very poor out of the DVD...
that is normal its the copy protection that taged
on the dis toc.....that is why the picture go black and disturbing color/ disconnect your firewire try this..
Feb 24, 2010 | Canon ZR100 Mini DV Digital Camcorder
Downloading Canon ES8600 Hi8 movie to Macintosh
Just connect the camera to you Mac by using Firewire.
Apr 07, 2009 | Canon ES8600 Camcorder
Dumping video
purchase a firewire cable to go from dv port of cam to computer-4-4pin for laptops 4-6 pin for mac and towers if comp has no firewire port-use pinnacle dazzle to convert a/v output to usb 2.o
May 17, 2008 | Canon ZR100 Mini DV Digital Camcorder
USB Port
To transfer video to your computer from the ZR100, you will need to connect the camera to the computer via the firewire interface. The ZR100 does not have a USB interface.
Jan 19, 2008 | Canon ZR100 Mini DV Digital Camcorder
Transfering video to Mac
Digital video on the ZR400 is transferred to a computer only via the DV out port, which will connect to a firewire port on a PC or a Mac. USB will not transfer video, only images to and from the card.
Nov 13, 2007 | Canon ZR400 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
372 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
