Question about Hitachi 53UWX10B 53" Rear Projection Television
My 53WUX10BA Red Power light will not go out
Started a week ago. Red LED power light stays on even when set is off. Don't know if set is on or off when input is turned off. Seems to be taking longer to power up, but that may be my imagination. Everything else seems okay.
  • bumos28 Nov 11, 2008
    mine is doing same thing look to see if dp 23 is out its on center board near center
    Problem Solver:
Hey junea i hboard its a green led all my leds are on as soon as its plugged in except that oneave same issue check too see if dp 23 its on center of board all mine are on except that one
Posted on Nov 11, 2008
Will not power up it worked fine then last week it stoped turning on it just turns off as soon as i turn it on
Posted on Nov 07, 2008
I have a new Viewsonic 2756L TV for like 3 weeks and it shuts down and doesn't want to turn back on. The Red light next to the sensor keeps blinking red when i tried to power on even from remote contr
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 06, 2014 | Televison & Video
Picture is black. sound went out a few weeks ago and now all that seems to work is the red power lamp turns on and I hear a click but that's all. I am not concerned about the picture since it is c
The click is a power relay on the main board and if the red light is on I would suggest looking inside to see if it has more than one relay--follow the power cord into the set----some of these sets have one relay but others have up to 3.
They are know for sticking open or shut. A tap on them can free them..A look inside even by a novice may also reveal something burnt or unplugged etc.
12_5_2012_3_12_13_pm.jpgview of relay bottom side is up.
Dec 05, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Red Power Light Stays on
Hi, you have a leaky diode, it will not hurt your tv it`s just annoying, my Hitachi has done the same thing for a year and I`m just too lazy to change it out, video-tek
Feb 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Samsung HLS5679WX/XAA turning on and off
I had this on mine too. It is a problem with the power supply. Samsung knows about it.
Nov 06, 2008 | Televison & Video
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Magnavox 15MF237 LCD - stuck in standby
just one idea.. some set you may program to stay on in case you use cable box and when you turn on the box tv turn on same time but may be defective tv there is relay,transistor and the micro that may be bad so check your settings again ... Good luck
Apr 10, 2008 | Televison & Video
Powers on shuts off after 10 seconds- red/green flash
its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Sep 22, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
95 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
