Question about Onkyo MC35Tech CD Shelf System
ONKYO MC35TECH aka R-805X
Where can I obtain a new power supply
    Problem Solver:
  • 20 Answers
Hi if you need a replacement plug for the system then you can buy them from any electrical store but if you want a transformer or anything product specific then you can contact Onkyo USA sevice centre on 201-785-2600.
Here is the Onkyo website where the number is from
. http://www.onkyousa.com/customer_support.cfm
Or for European service centres go here: http://www.eu.onkyo.com/indices/index_com_en_2008_5946251.html
Posted on Nov 01, 2008
Need e125a 125v fuse
http://www.intl.onkyo.com/downloads/manuals/pdf/r-805x_manual_e.pdf See page 4 of your manual at the provided link. This is the only mention of a fuse in the entire manual including plug specifications. 5amp.
Sep 15, 2015 | Onkyo For Parts R-805x Receiver
I have an onkyo R-805x that stopped working and makes a continuous clicking sound and no longer power up. Multiple people have posted this problem here but not info has been given. Is it the power supply...
Being a hospital electronics repairman (read I repair CT and MRI scanners), I recently had the pleasure of having our R-805x die on us with this exact same problem. I went through a lot of hoops to find the schematics on the system and what it came down to is the logic circuit on the main PC board, not the power board, has a logic control in there that is no longer able to determine the incoming voltage which prevents the system from locking in the relay on the power board. This is the reason for the clicking; the relay on the power module is energizing and de-energizing constantly.
I did not go any further than determining which board was causing the issue because ultimately it's going to cost about the same to repair (with shipping, headaches, man hours, etc) as a replacement system will be. I am currently researching replacment receivers for our MRI suite at this time.
Aug 20, 2010 | Onkyo Audio Players & Recorders
Onkyo Rec(R-805X)does not work-constant clicking when plugged in
i have a similar problem, i plug it in and let it click to its hearts content, it will speed up to a very fast rate then slow down and eventually stop... then the unit will work fine for a couple of days but the clicking will return its not a permanent solution but it works
Dec 04, 2009 | Onkyo Audio Players & Recorders
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Power problem in MC35Tech
Don't worry it has protection equiped that will not damaged your unit a fuse .Open the unit and look for the transformer inside near there where the fused is located. Free free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jan 12, 2009 | Onkyo MC35Tech CD Shelf System
Speaker was broken
partsexpress.com has lots of replacement speakers including polypropylene woofers.
Dec 15, 2008 | Onkyo MC35Tech CD Shelf System
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo MC35T model C707CHX
I have the same problem on a refurbished unit I bought 2 years ago. I read at the time that this is a common problem and you just need to send to an Onkyo service center. There are links on the Onkyo or ShopOnkyo website.
Lousy design I guess.
Mar 18, 2008 | Onkyo MC35Tech CD Shelf System
Onkyo FR-9GX
Try using a laser eye cleaner, this may help. ERF
Dec 23, 2006 | Onkyo MC35Tech CD Shelf System
Onkyo MC35Tech CD Shelf System Logo
619 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
