Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT-53wx53 hdtv
Tv comes on for about 2 seconds and then turns off. The red light blinks 3 times after it turns off.
  • 934 Answers
Check the voltage across R517, should read about 12v if not replace C524 which is your AC gournd return and possibly D509 feed diode. I suspect that you get enough voltage to trigger the relay but just before B+ happens the 12v line drops well below the trigger voltage and the relay re-opens.
Bill
Posted on Nov 13, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Posted on Mar 25, 2008
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Wont work
3 blinks is convergence error.
Apr 13, 2010 | Panasonic PT-53WX53 53" Rear Projection...
It won't come on the red light blinks 5 times then after about 5 seconds blinks 5 times again and repeats..
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Jan 11, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic rear projection model #- PT53WX53G will not turn on.
Happened to me, relays, either 1 of 2 so I had both replaced, about $300.00 to fix.
Nov 16, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Mar 25, 2008 | Televison & Video
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
