Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
Sony KV-40XBR800 HELP,The TV will only work if I unplug it for over night. When I watch it and turn it off it wont turn back on for 5-6 hours. It's trying to work but then it gos to standby and blinks 6 times. Thank for any help I can get. Thanks.
  • 5 more comments
  • Tibor Tancs Sep 09, 2006
    Do you have a part number for that regulator? Schematic Symble.
    Thank you.
  • sawadee Dec 09, 2007
    I have the exact problem. Unplug for 12 to 18 hours then plug it back in and it will run for ever. Turn it off and try to turn it back on and the relays click, then sometimes a loud click in audio and the system does not turn on. I get 6 blinks on the stand by light. I have the schematics in PDF format..
  • Anonymous Dec 19, 2007
    I've got the same problem.  My set has no picture or sound and the stand by light blinks 7 times then pauses when I turn it on by remote or manually.  Only until I unplug for overnight that it the picture and sound works.
    Any suggestions to fix?
  • aquiz1980 Dec 27, 2007
    what is the famous regulator problem? are you talking about IC504?
  • DoubleL Jan 03, 2008
    I have the same problem with mine.I need a schematic.Where is the regulator located?
  • rwcremer Jan 05, 2008
    I too have the KV-40XBR800 model and recently learned that my set would not power on... and observed the dreaded 6 or 7 flashing 'standby' LED. I spoke with a SONY rep and they had me unplug the set for a minute, plug it back in, and then power the unit back on to no avail. I cleaned all the dust out of the set to no avail. I tried reseating all the connections to no avail.
    For this set, since it is really heavy, I'll most likely need in-home tech support. Throwing out my back would probably cost me more than what it would take to fix the set. In any case, I learned that the flat rate for labor is $285, but does not include parts. I'm told that Sony parts are really expensive... so that's why I'm hoping to find a good blog to see if I can fix this myself. Oh, I also learned that Sony sets should only be serviced by 'apporved' Sony trained techs; this is because the special tooling and adjustments that are Sony specific.
    Well, hopefully someone can provide some insight... thanks.
  • Anonymous Feb 04, 2008
    I have the same problem. If I turn the TV off It wont turn back on. I have left it unplugged for two days and still wont come back on. I talked to a Sony repair guy and he said it was the b board (the high voltage Power Supply) this seems to be a fairly common problem has anyone ask Sony if they would foot the bill? This sounds to me like a bad part or bad design and if thats true Sony should take care of it. Anyone else agree?
    President:
  • 3,130 Answers
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Posted on Sep 09, 2006
Sony WEGA KV-34XDR960 works all day then about 1 or 2 am it shuts off & standby light blinks 6 or 7 times. I turn it back on but it eventually it shuts off again any where from 5 minutes to a couple of...
U have a thermal/intermittent issue. Given the age of the set and fact that other areas are now going, I think the cost effective way is to replace the set.
May 02, 2017 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Trinitron kv-32FS100 Black screen periodically, with sound, light blinks 5 times
5 blinks means there is a short in hor.section or the power supply
about 200.00 --- 250.00
Jul 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv 40xbr800
here is a list of some tv shops in miami i dont no them . so call around for the best price
ace electronics 305-969-4439
aaa video electronics 305-623-8875
american tv 305-649-5009
angel tv 305-222-4800
good luck doctor video
May 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony TV won't turn on :-(
our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Nov 08, 2007 | Televison & Video
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
791 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
