Question about Whirlpool Duet GHW9150P Front Load Washer
Drain Cycle doesn't drain right. Have to keep running the cycle to get water out.
Many times after the washer has finished I will open the door and the clothes are soaking wet. You have to put it through a secondary spin cycyle to getthem to drain. I have had a serviceman out twice and he can't find anything wrong with it. I just ran it again today and had to run the drain cycle several times. It keeps staring and runs for a few minutes and then stops and resets itself and starts up again. I almost seems like it can't get the load balanced. I am not over loading it and have tried running it on high spin and medium. I am at a loss on what to do. It takes forever to get the laundry done. Help!!!!
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds liker you have a pump/drain issue. ill assume that the technician removed the bottom acess panel and checked the "button trap" for foreign debris. if that was clear next i would check the hoses themselves, tub to pump hose may have something iin it. perhaps your drain hoseis clogged/ kinked. in some cases ive seen the pump sound as if its working but not pumping anywater out, in which case youll need to replace the pump.THis machine will not achieve high speed spin without draining adequate amount of water first. lastly you NEED to be using an HE detergent( specifically designed for front load washers)
Posted on Oct 30, 2008
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
Bosch was28440au logixx 8
What happens when you select the spin, or drain cycle? Does the washer drain the water and commence with the cycle? If the water does not drain then the door will not unlock on it's own. The pull cord should open the door regardless. If the water is not draining, remove the lower right access panel and check the strainer for excess debris. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Won't turn back on and finish cycle
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
Mar 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
