Question about Akai LCT2785TA 27 in. LCD Television
No picture I found 4 blown capacitors and replaced,,, I now have a green light and sound and can change channels but have no picture
    Champion:
  • 367 Answers
Are you sure you replaced all of the bad ones?Did you look at the top,and bottom of all the capacitors?Can you see the picture if you shine a flashlight on the screen?Did you replace any capacitors on the inverter that lights up the bulbs for the backlight,or just the ones on the power board?I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Nov 02, 2008
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
46"
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | Toshiba REGZA 47HL167 TV
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
Shutdown after video comes up the green power light stays on but the set will not shut down while changing channels. (philips 27 pt543s) ic702 eeprom and ic7200 control/signal processor has been...
Re:"shutdown after video comes up the green power light stays on but the set will not shut down while changing channels."
Hi.
I do not think this has anything to do with logic circuits and video processing. When you stay on one channel the horizontal and vertical alignment circuit works more than if you change channels all the time.
This is just a guess, but have a look at convergence ICs. when you keep changing channels the power amp ICs (or transistors) go on and off, if one of them is defective it will overheat and shut down.
Other possibility is an internal tuner failure. Also test using a DVS or VCR.
Nov 01, 2010 | Philips 27PT543S 27" TV
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
TV went out over time. Sound immediately, but no picture. Loud POP noise when i changed channel. After a while it would "warm up" and would work fine. now doesnt show picture at all. In monitor mode...
Check the power supply first for bac capacitors (learn more here about bad capacitors: http://en.wikipedia.org/wiki/Capacitor_plague)
I had replaced capacitors in my, hopefully it did not cause damages to other circuits such as backlight inverter board.
Nov 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
WS-65513 DM board caps replaced but green light continues
If I remember correctly, there are more than 4 caps on the DM board that need replacing.
Jul 25, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Akai LCT2785TA 27 in. LCD Television Logo
144 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
