Question about KB Gear JamP3 16 MB MP3 Player
It won't play
I have had a jamp3 player for several years without using it. Now when I try to use it, the screen says that I need stmedia.sys. But I don't have the disc that came with the player.
0 characters
1 Points
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Hi, my swimp3 was not used for the last 2 months. I charged it up full yesterday and when plugged into the computer it plays well (i.e I can format it, change songs, actually have it "play",...
Hello nehajo88,
Thank you for contacting us. I work in the FINIS Technical Support department and would strongly recommend that you go to our support page and create a ticket so we can process you for a replacement as it seems to be a defective unit. So please visit our support page ( and create a ticket and I will be happy to further process your case there.
Aug 02, 2011 | Finis Swi MP3 Player
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 09, 2010 | SanDisk Sansa e250 MP3 Player
File sys error
Download that. It contains a firmware update that is meant to fix the "file sys err" problem. I got it directly from the Coby website and it works perfectly.
Jan 26, 2009 | Coby MP-610 MP3 Player
RCA Opal 8 gb mp3 player stuck in initializing mode
I had this problem. I had to really try several different things to get the software to recognize the mp3 player. RCA does have download software that will format your MP3 player and put the firmware on the player. It would be better to get the firmware on without formatting if you have files already on it. Just be sure that you get the screen that shows it is connected to USB.
Jan 21, 2009 | RCA OPAL M4001 MP3 Player
Not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
Sep 22, 2007 | MP3 & Digital Media Players
KB Gear JamP3 16 MB MP3 Player Logo
27 people viewed this question
Top KB Gear MP3 & Digital Media Players Experts
Gyula Lacz
Are you a KB Gear MP3 and Digital Media Player Expert? Answer questions, earn points and help others
