Question about HP Pavilion dv9000z Notebook
File system error 1073741521
I can not install/download drivers and softwares. When I try to the file system error 1073741521 pops up and st everything.
  • sjsinjeet122 Mar 01, 2009
    I got problem with my vista home basic to open download files & also to open control panel
  • 186 Answers
As per the error message you had received, I beleive that the File System (Partition Table) in your Hard Drive is curropted because of which you are unable to store any data.
The only option available is to burn the requried data into DVDs and perform full recovery and reinstall the Operating System to factory default settings.
This will format the Hard Drive and will also recreate the File System (Partition Table).
Posted on Oct 30, 2008
I have tried to install jdk 7 on windows 7 starter edition, I am getting this error"Error 1335. The cabinet file 'st 170000.cab' required for this installation is corrupt and cannot be used....
Sounds like the installation file is corrupted in some way. Suggest downloading a new installation file from scratch, which you can download here
Also make sure that you have met the min sys requirements as detailed here
hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Computers & Internet
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
I get 2/3rds of the way into installing the software and driver with the set-up disc that came with the Epson V500 Scanner, then a Error Pop Up message appears saying the following. Could Not Copy...
Check that it is installing to the correct file. Normally C Drive "Program files" I would suggest you go to the control panel and locate and completely uninstall the Epson scanner program first. This will give you a clean install. Check that during the installation, the disc may ask where you want the program to be installed. If it has a suggestion, let it instal itself, where it thinks is best.
Apr 30, 2011 | Epson Perfection V500 Flatbed Scanner
File system error and Consent UI
Administrator is an account of your computer, all the activities are held in administrator account. Although there is no password set for administrator account but if anyone in your family or relative must have set up a password,that's a different thing. I suggest you to install your windows again,in order to reset your administrator password.
Oct 10, 2009 | HP Pavilion a1700n PC Desktop
How do i download adobe flashplayer without error? PLEASE HELP:)
If you are checking the "install" box in the download manager, try checking "save file" instead. Then you can unzip the file and install from the desktop, or whichever folder you saved it to.
May 01, 2009 | Compaq Computers & Internet
Lexmak x1240 all in one will not communicate with computer
Hi, I am writing you regarding your problem with the printer.
If the printer is still not printing, try first replacing the usb cable, and try a different USB port.
If still no luck , then you will probably need to reinstall the driver software, either from CD , or downloading the file from Lexmark website.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Always start printer setup with printer unplugged, and chose printer as default during install.
Mar 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
Hp deskjet 380
Click here:HP F380 Software & Driver downloads
Afterdownloading,find the file,doubleclick on the file, if you get introubles ,then followinstructions below to reset and reinstall:
  • Download driver from website and run the file.
Note:some printer does not work on Vista
Oct 04, 2008 | HP DeskJet F380 All-In-One Printer
Lexmark x4250
You can try to search for the drivers in this site, make sure you select software for you kind of operating system:
click below:
http://www.opendrivers.com/categorycompany/13/1287/printers-lexmark-free-driver-download.html
Mar 01, 2008 | Lexmark X4250 All-In-One InkJet Printer
Downloaded driver not recognized by computer...HELP!
Please try this:
right click My Computer > Click properties > Click Hardware > Devuice manager > Select and remove the printer .
And restart the computer.
When prompted show the location of the driver files. This should solve your problem. Otherwise please let us know...
Dec 16, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
HP Pavilion dv9000z Notebook Logo
2,082 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
