Phillips gogear 6gb says please connect player to pc and has a yellow triangle with a exclamtion point
  • Anonymous Nov 23, 2008
    exactly the same problem and my computer doesn't detect the Mp3
  • Anonymous Mar 08, 2009
    i have same problem please connect player to pc triangle with exclamation point. help
SOURCE: Phillips GoGear Problem
I got a 8gb gogear, and when i try 2 turn it on, it doesnt, and when i try to charge it it juzt appears a flashin screen, juz flashing, i dont know what to do...
Do anyone knows ??
please !!!!
I will b thankful....
PeacE
Posted on Feb 05, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips GoGear Mp3 player problem
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my phillips 1630 6gb is frozen on the gogear screen
Press volume + with the player disconnected from computer.
Continue holding volume + as you reconnect player to computer.
Continue holding volume + after you connect player to computer.
Windows will recognize it for what it is after 5 to 55 seconds and will say "Found Hardware Wizard" - go through re-installation.
Get the latest firmware upgrade after you are done by Opening Philips Device Manager - Click on Update Tab - this will prevent problem from recurring in future.
Note: if you have Windows Media Player 11, ignore everything I said. You must rollback to Windows Media Player 10, or this player will give you constant heartache.
-Tha Mp3 Doctor
Posted on Mar 20, 2008
titi2cute
SOURCE: problem with my mp3player please help
Have you tried to reset it. If not, try to hold down the power button while pushing the volume button up. That helps alot.
Posted on Jun 08, 2008
SOURCE: device manager
want connect to pc
Posted on Jun 19, 2008
Gateway laptop pad dont work any more with out a mouse connected
Okay, the drivers might have failed. Try going to device manager by clicking on start at bottom left (assuming you're not in win8) Then right click on "My Computer" then click on "properties" then click on "Device Manager". under "Mice and other pointing devices" is there an icon with a yellow triangle and an exclamtion mark? if so right click and choose "update driver software"
Nov 28, 2013 | Toshiba Satellite Pro M300-S1002X Notebook
Philips GoGear Mp3 player problem
if the player is od the battery may be dead and gone, if not there should be a vry snall pin holeon the player somewhere, once you find it stick smething of the correct size in the hole and push down for thirty seconds, if this doesn't work go to the Phillips website to find that player and search for answers.
Feb 13, 2009 | Electronics - Others
Need download phillips gogear 4gb software
i need downnload phillips gogear 4gb software to add hardware
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect the GoGear to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 19, 2008 | Philips GoGear SA5285/37 Digital Media...
Device manager
Go to the phillips website and go to the support page. From here you can download the software from the disc by searching your specific model
Jul 29, 2008 | Philips GoGear HDD075/17 MP3 Player
Problem with my mp3player please help
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
My phillips 1630 6gb is frozen on the gogear screen
-Tha Mp3 Doctor
Mar 19, 2008 | Philips HDD1630 MP3 Player
Phillips Go Gear 6GB
The Phillips website has a solution for this:
Go to the FAQ for this mp3 player. It'll tell you to install the Device Manger which will repair the problem. I've done this, however, the Device Manager claims my mp3 Player is not connected.
Try this yourself, you might have better luck.
Oct 27, 2007 | Philips HDD1630 MP3 Player
261 people viewed this question
 Grubhead
Grubhead
