Question about Onkyo Audio Players & Recorders
Onkyo Receiver. Front panel LED display is dark, volume knob backlight is on, on-screen display works, all audio and on-unit buttons seem to work (its just the LED front panel display that is out)
  • Anonymous Mar 15, 2009
    I have the same problem w. my txds 595.
  • 21 Answers
SOURCE: Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Posted on Sep 03, 2007
  • 45 Answers
SOURCE: Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Posted on Nov 05, 2007
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
SOURCE: Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
Posted on May 21, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
How do I get the electronic digital display to light up.
Hi Dudley, I would suggest that you try the following reset:
To do the reset you need to turn the receiver on then on the front panel of the receiver press and hold the "VIDEO1/VCR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
Thanks, JT
Sep 12, 2015 | Onkyo Tx-900 Quartz Synthesized Tuner...
ONKYO TX-SR307. Problem with volume/sound getting lower. "Setup" does not alter / resolve the issue. Please help
Hi, if this has not been resolved please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Mar 02, 2015 | Onkyo Audio Players & Recorders
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Volume is stuck on max. The pot does not seem to be the issue. I do not have a remote. Tried to connect other remotes but unable to find a code that will work. Machine is new to me. Bought it for...
Do you have the manual and have you thumbed through it?
Register and download the manual for free at
retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR700-Receivers-manual/id/365ag223/t/2/
It always puzzles me when someone fixates on the remote when a unit has front-panel controls. You say "The pot does not seem to be the issue." Does that mean it is ineffective or is it faultless in your estimation?
The HUGE volume knob (#16 on page 8) controls volume (in the main zone), too.
If your complaint involves speakers on Zone 2, the up/down arrows at #22 on page 8 apply.
Feb 26, 2011 | Onkyo TX-SR700 Receiver
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
Receiver lcd display doesnot work
Does the 605 have the "pure audio" setting (my 705 does)? If that is selected, it cuts out the lcd display on the front.
Jan 04, 2008 | Onkyo TX-SR605 Receiver
Front buttons won't work
The microprocessor may be locked up. While pressing and holding "video 1", press "speaker A". When "clear" appears in the display, the micro has been reset to the factory default condition. To do a full reset without taking it apart, it may have to sit up to 3 weeks for the backup battery to run down.
Dec 21, 2007 | Onkyo TX-DS474 Receiver
Nov 04, 2007 | Onkyo TX-DS939 Receiver
No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
Nov 16, 2006 | Onkyo TX-SR601 Receiver
97 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
