Question about Xerox Phaser 8560DN Laser Printer
Using too much cyan
Printer say to add ink. I add ink and it goes through its warm cycle and all the ink winds up in the wast tray and it asks for more ink. Is it the ink loader, the unit that melts the ink or the print head? Thanks
  • 208 Answers
SOURCE: Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Posted on Dec 07, 2007
  • 2072 Answers
SOURCE: clogged print head
What you can try is going onto the Xerox.com site and loading what is call Jet Substitution it will change the ports being used.
That could help.
Load it to your laptop and then run. Sometimes helps.
Unfortunatly that is a very expensive print head.
Posted on Feb 12, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Posted on Feb 21, 2008
I think you could use the waste ink for your printer. I think it will just produce the same output that it produces before. Just try it for your self.
rollyn
New Phaser 8560 Solid Ink technology from Xerox. Better Prints, lower printing costs & less Ink Cartridge Waste. http://www.concordsupplies.com/find.html?search=manufacturer&search=model&value=Xerox&value=Phaser+8560
Posted on May 05, 2008
SOURCE: XEROX PHASER 8550
How do you only print black, I have only black cartiages left, but it still asks for the other colours.
Posted on Jul 21, 2008
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Light Cyan printing problem in R230 model printer noozle seems to be bocked. From: nain
Cleaning cycles use lots of ink. Go to http://www.inkproducts.com/ and buy a CISS for your printer. It will save you tons of money, you never change cartridges and never run out of ink [yes, you do have to fill the tanks once in a while] Bulk ink is cheap. The CISS will pay for itself in a month. Don't forget to get a Waste Ink Container, it hooks up to the printer and instead of the unusable ink going to the waste ink pad, it goes to the container which can then be emptied, washed and used over and over. The waste ink pad when full will need to be replaced or the printer will not print. Changing the pad is messy and a PITA. They have cleaning kits.
Dec 28, 2009 | Epson STYLUS R230 InkJet Photo Printer
My cyan ink ran out so I replaced it (brand new cartridge) but it is not printing any cyan?? Help please!
The ink path probably dried out. Sometimes repeated cleaning cycles will fix it but at expense of wasting a lot of ink.
You might want to get a refill kit and use syringe to force cyan ink into that channel or purge the channel with the cleaning fluid.
Sep 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Xerox Phaser 8500 Error 09,005.40:100473
You don't have to take all the printer apart just the ink loader. Which is held mostly by the side covers. Get a flat head and break down the peaces left over on the cyan ink and flip upside down the ink loader and that should make it work again with no problem.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Hi Carmichael55:
Here is your problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to advance in the ink loader chute.
Go to
Step 3.
Remove any blockage and/ or replace the ink stick.Run clearISCfault
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run clearISCfault test to clear the error.
Hope this helps
Jul 30, 2009 | Office Equipment & Supplies
The printer has ink in the chambers, but message keeps coming up
Ink sticks are blocked in the ink loader assembly.
Are using generic ink sticks "Media Sciences" perhaps?
Remove all ink sticks and reinstall.
Feb 24, 2009 | Xerox Phaser 8550DX Laser Printer
XEROX PHASER 8550
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8560DN Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
