Question about Belkin (F5D7230-4) Router (587009)
Sudden inability to connect
I've had no problems at all with my Belkin until yesterday when my wife's aunt attempted to connect with her laptop. Apparently this somehow caused mine to disconnect and now I cannot seem to get the wireless to work. I've disconnected and reconnected....disabled and re-enabled with no change. Any ideas?
  • chris g Oct 29, 2008
    It gave me the response: no operation can be performed on Wireless Network Connection while its media is disconnected.
    When I then switched the cable to from the laptop to the modem (like I should have done in the first place probably) it repeated the above message as well as saying that the Local Area Connection's media is disconnected. Problem with the wireless card maybe? Just bought it 2 weeks ago and have had zero problems.
  • 1,124 Answers
Try to renew your IP address
Start >> Run >> type ....cmd >> one black screen appears.........type...... ipconfig /renew
And try to get the internet again
Posted on Oct 29, 2008
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Belkin Wireless router problem?
Sounds like you took all the right steps.In add and remove programs at the control panel,remove your wireless card drivers and anything related to it.
Be sure to write down your wep security key from your router first.
Then remove the card,reboot,put the card back in,then reinstall the drivers.
If this does not work the wireless card may be bad.
Hope this helps.
Apr 14, 2010 | Belkin Computers & Internet
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Laptop gets message'cannot connect' to belkin wireless g router when wireless connection is attempted. Hard wired connection no problem.
There could be a security key required by the router to establish connection with the laptop. Check that & fix it.
Jun 30, 2009 | Belkin (F5D7230-4) Router (587009)
Help me
you have to connect to a computer to erase all the songs.
Mar 21, 2009 | Apple iPod nano
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Stopped providing connectivity to internet or LAN
What is the color of the power light? If it's solid red then that only means that there is something worng with it. And since you already rebooted the device a couple of times, you cant to reset it. You press the reset button on your rotuer for 10-15 sec. its usually located on the back of the router. Now let me also remind you that it will erase all of the settings on your router if you do this, so you will need to reconfigure it after you reset it.
Just reply to this post to let me know what will happen.
May 13, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Audio and Video (Windows Media, Real Player, and player software) freezes up
can u speedtest your bandwith just compare Dell Latitude D620 & Dimension 8400 check ther bandwith.
Mar 13, 2008 | Dell Latitude D620 Notebook
Belkin (F5D7230-4) Router (587009) Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
