Question about Sharp LC-42D43U 42 in. LCD HDTV
Poor Volume We have the same issue with our LC-42D43U. The volume is poor. I called the store that we purchased it with and they said top buy an Amp.The old TV had good volume, so it isn't a cable or receiver problem.
  • hardhearing Oct 29, 2008
    I found this on another site, tried it and it WORKED. It took a few swiches, but it worked.
    I have a Sharp LC-46D43U LCD TV. I think this is a entry level for
    large lcd tv's. With the volume all the way up at 60, my wife and I
    could barley hear the tv. I was playing around in the menu and some how
    have the volume at almost twice the volume. What I did was:
    Go into the menu
    Go to option
    Go to output select
    and change from fixed to variable and back to fixed. You may have to do this a few times.
    Sometimes the volume goes loud after 1 try and sometimes it may take 10 or 20 tries.
    But if I change any settings, even the channel sometimes the sound goes back down to where it was.
    Has anyone done this, did it work for you. I don't know very much about electronics and I have now ideal why this happens.
    I wonder if this is just something with my tv.
    Go into the menu
    Go to option
    Go to output select
  • 405 Answers
This is a design problem, unfortunately unrepairable.
Posted on Oct 24, 2009
I have a Sharp Aquos LC-46D43U TV and the audio control is continuously going down to zero although I use the remote to increase the volume. The TV is automatically decreasing the volume to 0. I hea
this is a problem I rectified yesterday.
the audio ic is overheating thats why the tv is fine when cold and
after a few hours the volume disappears.
I fitted a heatsink to the ic chip as the sharp one is very poor quality
Sep 19, 2014 | Televison & Video
Poor volume on my sharp lcd tv
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 29, 2012 | Sharp LC-32DH500E LC-32DH500E 32 inch LCD...
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
Nokia 2760 mobile poor volume on incoming calls. difficulty hearing incoming voice calls.
Check all tones settings and adjust the volume, check incoming alert ringing, or your speaker need to replace.
Sep 27, 2011 | Cell Phones
NOKIA 3315 sound problem (poor sound quality). Please Help!
Poor sound and quality: If you hear buzzing sounds during conversations or either during sound alerts, bring it to the nearest repair shop for replacment of speakers. However, if you only mean that you had a hard time listening to a call because of low volume, then do the following:
1. during the conversation, press the UP button, then, you will see the volume bar to appear. Keep pressing it until you reach the desired volume. When your done, just stop pressing or tapping and it will automatically return to call menu.
Enjoy Nokia 3315.
Jun 10, 2011 | Nokia 3315 Cellular Phone
Even at full volume the sound is poor and HUMAX 9300TPVR
a few thoughts...
the humax remote vol is at the top yes?
are you Scart connected or hdmi? try the other if poss
or are you using the optic/audio outs?
Oct 20, 2009 | Televison & Video
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Dec 12, 2008 | Acer V223WBD Monitor
Low sound volume when making a call
be sure there's nothing covering the speaker when you're talking. i would try looking in the tones settings if you have that. but some phones just don't have really good audio, but if this is a recent problem, then i'd suggest taking it to the store and getting it looked at
Jul 15, 2008 | Nokia 1110i Cellular Phone
Sharp LC-42D43U troubleshooting with the maximum volume sound
Found this on another site and it worked, had to switch back and forth a few times but it worked........
I have a Sharp LC-46D43U LCD TV. I think this is a entry level for large lcd tv's. With the volume all the way up at 60, my wife and I could barley hear the tv. I was playing around in the menu and some how have the volume at almost twice the volume. What I did was:
Go into the menu
Go to option
Go to output select
Mar 03, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Dial a nuber, I connect but I cannot hear anything
once you have connected on the call press the volume button to raise the earpiece volume.
this can only be done while on a call
Nov 07, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Sharp LC-42D43U 42 in. LCD HDTV Logo
123 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
