Question about Toshiba Computers & Internet
Toshiba sat4200 bios damaged error screen - Toshiba Computers & Internet
    Scholar:
  • 195 Answers
This usually happens when somebody goes in there and tries Re-setting their settings from Default. try turning the computer off and then back on, when the setup screen appears press the appropriate F-Key to enter your BIOS. at the bottom of the screen their should be a option to Enter Default Settings, Save and Exit, Take that option and Re Boot. Good Luck.
Posted on Oct 30, 2008
Toshiba tecra p5 up on black Screen on PCI EXPRESS ERROR can't boot????
If you can't boot to the bios, you are in major trouble. You can try and see if the manufacturer has a bios flash program you can load on a Flash drive to flash the bios...you will have to research that on another computer, obviously.
Nov 25, 2014 | Toshiba Computers & Internet
Bad check sum cmos
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Bios(block 3) is damaged
https://bugs.launchpad.net/ubuntu/+bug/507723
..error message:
Bios (Block 3) damaged. Contact serviceman.
Happens on Toshiba laptops trying to install Ubuntu.
Not fixed after creating floppy disk with v1.30 of BIOS flash rom.
No known solutions yet.
Nov 05, 2011 | Toshiba Portege 4005 (PP400U-002G2JB_1) PC...
When I start my computer (a 1 month old Toshiba laptop with Intel i5 core processor that came with Windows 7) it pauses on the prompt screen and then error message "error sending end of post message...
This is usually a BIOS error. In order to fix this you must either perform a system recovery(perferred), or simply restart your BIOS by following these instructions:
System Restore:
1) Go to the start menu.
2) Go to "Accesories."
3) Navigate to the "system tools" sub-folder, and click "system restore."
4) Follow the on screen instructions, and select a date before the problem starter occurring.
If that doesn't work,
Resetting BIOS:
1) Restart your computer.
2) Press the "F2" button while your computer is booting up over and over again until you arrive at the BIOS setup screen.
3) Press "F9" to reset BIOS.
4) Press "F10" to save your previous BIOS settings.
Mar 09, 2011 | Sony Computers & Internet
Toshiba x200 black screen of death. One long beep, twoo short beeps. Help please.
The error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Do you have access to bios?
If you have access to Bios, I suggest you to load optimal defaults and try booting, It must fix your issue.
If you do not have access to Bios, I suggest you to remove the recently added hardware (if any) and try booting.
If there is no recently added hardware, It-seems that Video (Mono/CGA Display Circuitry) issue, I suggest you to contact near by service center.
Regards
May 24, 2010 | Toshiba Satellite X200-AA3 Notebook
I cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
Booting error(err:tos0005)
GThis error is caused by a damaged Boot Record on your Hard Drive. The solution is to use your Restore Disk and Repair your system.
Sep 23, 2009 | Toshiba Satellite M105-S1021 Notebook
My toshiba wont boot past the BIOS screen. What
Several things could be wrong, the most likely is a failed HD or damaged windows install. If you press F12 it should take yuo to the boot menu, reply back with the list of options and I'll take a look,
Chris
Aug 10, 2009 | Toshiba Satellite A85-S107 Notebook
Damaged Bios
Please mention the model number
Nov 25, 2008 | Toshiba Portege 3480CT Notebook
Computers & Internet Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
