Question about Garmin GPS 76 GPS Receiver
Screen goes blank except for a black line - Garmin GPS 76 GPS Receiver
  • 2 more comments
  • Redleg72 Nov 04, 2008
    This just happened today. Shuts off with just a black line remaining. The line will go away once the batteries are taken out. I tried using the car adapter for power, but still had the same problem.
  • gimecoffee Nov 15, 2008
    My Etrex Legend starts up and then goes blank with the black line down the screen.
  • Anonymous Dec 25, 2008
    has the update come available for garmin 76 waas problem
  • Anonymous Apr 27, 2009
I had the same problem with my 76S. Called Garmin to send it back for service. They said it was a problem with new WAAS signals that causes the freeze/black line. Disabling WAAS using menu/system solved it for now. They are working on a software update Real Soon Now.
Posted on Nov 18, 2008
Black Screen in Defector mission of COD7 (Black Ops)? In Call of Duty black ops, in Defector mission, after pushing the door, car explodes and screen goes to black but sound remain properly. I have the ps3...
I just had this problem. The screen was blank, except for the direction and compass in the right hand corner, but the sound is still there. Seems to be a bug. I simply shot up a few people, went to the door, waited about 4 seconds without pushing the door, then just before the car came towards us, hit the square but to help push. Then it seemed ok. If you push from the start you may find the screen goes blank.
Dec 28, 2010 | Activision Call of Duty Black Ops
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Won't turn on or off screen is blank
I had this problem for about 3 hours except that it was a totally blank screen. Unscrew the back of it and take the battery out for about 10 seconds. Put the battery back and it should reset totally. Don't worry about the songs, they'll be fine.
Mar 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
My screen is blank on all modes except playback and setup
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
Apr 30, 2007 | Nikon COOLPIX P4 Digital Camera
Garmin GPS 76 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
