Question about Reddy Heating & Cooling
Kerosene forced air heater will not light, only hums.
I have a 60,000 BTU forced air Reddy heater. It has been setting for three years. When plugged in it only hums. Could this be the motor?
Is it possible it just needs to be freed up and oiled?
Thank you.
  • 232 Answers
Your problem may be as simple as the vanes of the rotor stuck to the pump body, or a rats nest binding the fan blade, or the starter relay being defective (if equipped ) . On the other hand, the bearings in the motor could be frozen up. The motor is not servicable and must be replaced. Start by disassembling the air pump, remove the vanes & rotor, then attempt to start the motor. If it still hums, then you have motor or relay problems.
If the vanes were stuck, clean it up, reassemble (no oil) , set the pump pressure.
Posted on Oct 30, 2008
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Posted on Dec 06, 2007
My reddy heater works great for a minute or less than just turns off. i leave it plugged in thinking it will turn back on but it never hapens
It's not seeing a flame. The sensor that "sees" the light from the fire is probably not working and thus shutting it off thinking it's not firing.
Dec 22, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Heater flares and expels smoke rings every second or so. It smells like too much kerosene in the air.
sounds like the air filter is plugged<its small on the injector pump< you"ll have to look for it as i can"t remember exactly where it is> its been years since i worked on one sorry>
Dec 11, 2009 | Reddy Heater 60,000 BTU Kerosene...
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
60000 heater kerosene fires up but shuts off shortly after
Check the entire fuel like to the tank. They tend to break, plug up, etc. which causes a lot of problems. The strainer in the bottom also plugs up. Rick
Apr 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Heating & Cooling Logo
269 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
