Sony kp61hs10 tv picture wont line up
Pixsals wont line up have red line top of screen
  • fknippenberg Nov 10, 2008
    so there is no way to fix this problem without paying out the kazoo? where is the fuze located
  • 50 Answers
THIS PROBLEM IS CALLED CONVERGENCE ...MOST OF THE PROBLEMS ARE CAUSE BY CONV. IC'S GOING BAD AND POSSIBLY A FUSE BLOWN-- U NEED A TCEH FOR THIS REPAIR..TUNICA
Posted on Oct 29, 2008
  • TUNICA Nov 11, 2008
    SONY'S HAVE A CONV. CIRCUIT BOARD BEHIND THE FRONT COVER UNDER NEATHTH THE KEYBOARD,,YOU HAVE TO REMOVE THE COMPLETE PANEL..WHAT'S THE MODEL # TUNICA
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
Jan 04, 2018 | Televison & Video
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is...
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
Jan 07, 2010 | Sony Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
Feb 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
