Home | GE | 46GW945 46 in. Rear Projection Television | GE 46GW945 Pro...
GE 46GW945 46 in. Rear Projection Television
Problem for GE 46GW945 46 in. Rear Projection Television
GE 46GW945 Projection has color alignment problems after power outage
By NaviUser on Sep 08, 2006
Hi there, I recently had a power flucuation in my area, with the power rapidly turning on and off. This all occured in the span of about ten seconds, before I had the sense to turn anything off. When all was said and done, my GE 46GW945 BigScreen Projection TV, which is several years old, had what appeared to be misaligned colors. The red is off to the side, the green is off on the other side, and everything has a bit of an afterimage. My neighbor has the exact same GE 46GW945, and he is able to access a menu option for restoring allignment automatically or manually. Odd thing is, I just don't have that. The space in my menu just isn't there. Has anybody seen this kind of problem before?
Same Problem
Apr 12, 2009
-   How do you replace the Convergence IC's?
pato -   Guest
Best Solution
posted on Sep 09, 2006
Helpful)
techman
Rank: Guru  GE Expert
Rating: 86%, 7605 votes
Try unplugging for 12 to 24 hours. if that doesnt help replace the convergence IC's
Was this helpful?
Yes
No
Popular Solutions for GE 46GW945 46 in. Rear
Questions and Unsolved Problems for GE 46GW945 46 in. Rear
Do you recommend GE 46GW945 46 in. Rear Projection Television?
Answer
Answer
GE 46gw945 52" Just moved from one house to another, tv was wrped in blankets and wraped in... (More)
Answer
I have Dish network and after they readjusted my dish the universal remote did not control the GE... (More)
Answer
the picture is distorted. the color is splitting from the image. red, green blue yellow is... (More)
Answer
posted by luckey777 on Apr 16, 2009 i have this model GE 46" projection tv that does not power... (More)
Answer
The picture on my GE 46GW945 is getting dark. I turn the brightness up, but it doesn't get any... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 46GW945 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
