Question about Giottos MT 8180 Tripod
Broken part on MT 8180 looking for replacement part
The black plastic key that you use to tighten the collar around the tube broke off....I can still tighten it using pliars but would like to find a replacement key that fits the bolt. Anyone know where I might find a replacement key?
  • knightflyer9 Nov 04, 2008
    Thanks I'll try that...I didn't think about that...appreciate the suggestion....
    Problem Solver:
  • 5 Answers
ACE Hardware.  What you are looking fore is a "wing bolt" as opposed to a wing nut.  They have them in both SAE and Metric.  At least our local store does.
Posted on Nov 03, 2008
1998 vw T4 Transporter the black collar around ignition has broken off. Now car will not start.
if collar--cover around ignition damaged yes can cause the ignition switch not read the key and not let car start
Jul 14, 2017 | Cars & Trucks
What do you remove to have access to spark plugs
Tools you will need before you start1. 1/4" ratchet2. 1/4" extention3. 10 mm socket, 1/4" drive4. small flat bladed screwdriver5. 3/8" ratchet6. 3/8" long extention7. 5/8" spark plug socket, 3/8 " drive8. air compressor with blow gun or can of compressed air9. long needle nose pliers10. 1/4" internal diameter rubber hose 8 inches long11. wire coat hanger12. neverseez lubricantProcedure1. Remove the two 10 mm cap nuts on the top plastic housing over the engine2. Remove the two fasteners on the back of the housing and remove the plastic cover3. You will see four plastic blocks with four wire clips on each block. These blocks are individual coils for each sparkplug.4. Use compressed air to blow out debris around the blocks5. Use the small flat bladed screwdriver to carefully lift up on the tab that holds the electrical connector onto the block and slide the wire clip off the block.6. Remove the 10 mm bolt that holds the plastic block onto the engine. Use the needle pliers to firmly grasp the plastic screw and pull straight up to remove it
7. Loosen the 10 mm nut on end of the plastic rail that holds the wiring harness for the blocks so that the round plastic washer on the bottom of the block will not break when you pull off the block8. Carefully pull the plastic block out of the engine. There is a 4 inch tube attached to the block that extends into the engine to the spark plug. It will take some twisting and pulling but you must be careful not to catch the back part of the round plastic washer that you cannot see, on the bottom of the plastic wiring harness.9. The spark plug is at the bottom of the 4 inch hole.10. Blow compressed air down the hole to remove debris11. Use a 5/8 sparkplug socket with a rubber collar on the 3/8" extention to remove the spark plug. The rubber collar will hold onto the spark plug as it is removed.12. The NGK website recommends making sure the spark plugs have the correct gap .044 but the spark plug box says not to adust the gap because you might damage the needle point iridium tip. The new spark plug has a protective cardboard tube that is removed.13. Spark plugs can stick inside aluminum heads and break off when you try remove them, leaving only the threads of the plug inside the engine which will necessitate removing the head to remove broken spark plug. Putting neverseez on the threads of the new spark plug will prevent that in future spark plug changes14. Now comes an interesting choice. You can use the rubber tube over the neck of the spark plug to slowly drop it down the hole and hand tighten it or you can use the spark plug socket with the rubber collar. If you use the spark plug socket, the rubber collar will stick to the plug and you will pull off the extention, leaving the socket in the hole. A pair of long needlenose pliers will reach into the hole and remove the socket, but the rubber collar may remain on the plug and you will have to bend a piece of coathanger with a short 90 degree tip to reach into the hole and pull out the rubber collar. The rubber collar is there to prevent you from cocking a regular 5/8" deep socket at an angle which will break off the neck of the sparkplug, necessitating another 10 dollars and another trip to the auto parts store.15. After the spark plug is hand tight, give it 1/2 turn more.16. Replace the square block, being sure that the black silicone gasket on the bottom of the round plastic washer does not get bound up on the engine post where the 10 mm bolt goes. Tighten the bolt17. replace the electrical clip.18. Go to the next spark plug and repeat the procedure.19. After the last spark plug is done, be sure to retighten the 10 mm nut on the wiring harness rail20. Replace the plastic cover over the engine and you are done
Nov 09, 2011 | Toyota Cars & Trucks
I have a pioneer car sterio that I need to remove how do i get it out of my dash? do i need a special tool
If it's an aftermarket stereo, it can be removed without taking the dash apart. It depends on how it was installed. Remove the thin plastic collar from around the radio, it may be easier to remove it with the faceplate detached. Look on the sides for thin metal tabs you can press then in and slide the radio out carefully with a flat screw driver.
Some installers will screw the radio into a dash assembly and the radio will not come out until you remove the dash. Usually cars that have a black plastic pocket either directly above or below the radio are screwed in and don't come out as easy.
If you remove the faceplate and collar, and see a thin metal cage around the radio it should slide out nice and easy with a flat screw driver or the "keys" that come with the radio when purchased new. These "keys" are just long skinny flat pieces of metal and are real cheap.
Jul 18, 2011 | Car Audio & Video
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
Opened the cannister to remove the bag. The tube
Steve,
This may be, and I stress MAYBE an issue with lining up the snap on the collar at the end of the hose (black tube). Please look carefully, using a flashlight or other bright light if necessary, to see if there is any indication on the collar for lining it up to 'snap' together. Unless the locking mechanism is broken off this should solve the problem.
Dec 04, 2009 | Miele Cat & Dog 326i Bagged Canister...
Where are the spark plugs in a 1999 Toyota Carolla and how do I replace them?
Procedure:
  • 1. Remove the two 10 mm cap nuts on the top plastic housing over the engine
  • 2. Remove the two fasteners on the back of the housing and remove the plastic cover
  • 3. You will see four plastic blocks with four wire clips on each block. These blocks are individual coils for each spark plug.
  • 4. Use the small flat bladed screwdriver to carefully lift up on the tab that holds the electrical connector onto the block and slide the wire clip off the block.
  • 5. Remove the 10 mm bolt that holds the plastic block onto the engine. Use the needle pliers to firmly grasp the plastic screw and pull straight up to remove it
  • 6. Loosen the 10 mm nut on end of the plastic rail that holds the wiring harness for the blocks so that the round plastic washer on the bottom of the block will not break when you pull off the block
  • 7. Carefully pull the plastic block out of the engine. There is a 4 inch tube attached to the block that extends into the engine to the spark plug. It will take some twisting and pulling but you must be careful not to catch the back part of the round plastic washer that you cannot see, on the bottom of the plastic wiring harness.
  • 8. The spark plug is at the bottom of the 4 inch hole.
  • 9. Use a 5/8 spark plug socket with a rubber collar on the 3/8" extension to remove the spark plug. The rubber collar will hold onto the spark plug as it is removed.
  • 10. The NGK website recommends making sure the spark plugs have the correct gap .044 but the spark plug box says not to adjust the gap because you might damage the needle point iridium tip. The new spark plug has a protective cardboard tube that is removed.
  • 11. Spark plugs can stick inside aluminum heads and break off when you try remove them, leaving only the threads of the plug inside the engine which will necessitate removing the head to remove broken spark plug. Putting antisiez on the threads of the new spark plug will prevent that in future spark plug changes
  • 12. Now comes an interesting choice. You can use the rubber tube over the neck of the spark plug to slowly drop it down the hole and hand tighten it or you can use the spark plug socket with the rubber collar. If you use the spark plug socket, the rubber collar will stick to the plug and you will pull off the extension, leaving the socket in the hole. A pair of long needle nose pliers will reach into the hole and remove the socket, but the rubber collar may remain on the plug and you will have to bend a piece of coat hanger with a short 90 degree tip to reach into the hole and pull out the rubber collar. The rubber collar is there to prevent you from cocking a regular 5/8" deep socket at an angle which will break off the neck of the spark plug, necessitating another 10 dollars and another trip to the auto parts store.
  • 13. After the spark plug is hand tight, give it 1/2 turn more.
  • 14. Replace the square block, being sure that the black silicone gasket on the bottom of the round plastic washer does not get bound up on the engine post where the 10 mm bolt goes. Tighten the bolt
  • 15. replace the electrical clip.
  • 16. Go to the next spark plug and repeat the procedure.
  • 17. After the last spark plug is done, be sure to re-tighten the 10 mm nut on the wiring harness rail
  • 18. Replace the plastic cover over the engine and you are done.
Good luck and hope this helps.
Sep 17, 2009 | 1999 Toyota Corolla
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Giottos MT 8180 Tripod Logo
173 people viewed this question
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
