Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I need the default ip address for the Konica Minolta C350
I need the default IP address for the C350. Also how do I change it in the machine? And how can I find it if it was changed?
  • Anonymous Jan 15, 2009
    I cannot log in my c350. The network cannot find my printer. It has an IP address that is visible on the command workstation but it will not make the hook up. Any ideas?
  • 167 Answers
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
  • Kevin Hayes
    Kevin Hayes Feb 17, 2009
    As far as the other C350 and the Fiery.
    You need to give the Copier a seperate IP address different from the Fiery.
    They both need to be set up on ypour network, with a Fiery you need 2 IP numbers.
Default TCP/IP Setting
Posted on Jul 11, 2009
I have a Konica Minolta BizHub C351 need to know how I can set up the ip address in order to be able to print to it. And any advice you can give me on the drivers using Microsoft Windows 7
Go to Konica Minolta web site US I assume down load driver for your machine. GO to Admin Settings PW 00000000 or 12345678 default. Network settings common setting to get IP address info
Dec 19, 2014 | Konica Minolta bizhub Office Equipment &...
Why can I detect Konica Minolta c350 with my computer (windows xp) through networking? please explain this problem.
This is a very common issue in connecting printer in a LAN.
First of all you need to set up a fixed IP address in your Printer. Please follow this as per your user manual. Secondly you need to check whether this fixed IP address is reserved or not. If it is not reserved, please reserve this Fixed IP address assigned to your printer with the unique printer MAC address. You need to follow the usual manual as per your router in how to reserve fixed IP address for a particular device. Thirdly you need to allow your firewall settings in your PC to get through communication with this printer, else your PC will be blocked to communicate with this printer.
Finally just install the printer driver program in your PC and it should work now.
Jul 07, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
7,908 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
