Question about Maytag MMV5207A Microwave Oven
MAYTAGE MICROWAVE MMV5100AAB-SWITCHING BREAKER WHEN STARTING
I have a 2001 Maytag Microwave model #MMV5100AAB which has been constantly tripping the breaker when either you select the minute buttons to operate or by manually putting in the cook time. I unplugged the microwave from the outlet which is above in the cabinet and I even ran an extension cord to 2 different outlets and it also tripped the breaker. My electric is new and I have 20 amp breakers which this microwave only runs on 13.8 amps. I know there is a short or something in the microwave, and I was wondering if this is an inexpensive fix or should we just go out and buy a new microwave. Please help.... Thanks.
Is there a way to over ride the main board start button so i will know if the board is bad. or away to test this?.
Posted on Nov 06, 2008
Microwave keeps tripping circuit breaker
Chances are you have a shorted "monitor" interlock switch, or its mount is broken.
See this door switch help file.
You can find links to helpful exploded view diagrams and part ordering help here.
To give you more specific help, we would need the brand name and
full model number of your microwave.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 30, 2012 | Microwave Ovens
Maytag mmv 4205 microwave, plugged in but no power
Check the house circuit breaker to see if it has tripped or the internal line fuse and see if that is blown.
Dec 06, 2010 | Maytag MMV4205 Microwave Oven
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Maytag Microwave Ovens
Runs for 20 seconds and trips breaker. making a loud noise when running
heatman101
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
Looking for the manual
Here is the link for your Maytag manual.:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MMV5100AAB.pdf
Note that the manual is a pdf document which requires Adobe Reader. If you don't have Adobe reader installed on your computer, you can download it for free from www.adobe.com
Best wishes,
Graemevm
Apr 19, 2010 | Maytag MMV5100A Microwave Oven
My microwave is not getting any power and the breaker is not tripped
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
m
Apr 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Model #MMV5100AAB built 01/2002 no power
Check the back panel for a breaker reset. If none, remove the case cover (pull the plug) and look for any blown fuses. If look ok, then check the interlock switch(es) for function when the door is closed. They are micro-switches and should make a distinct 'click' when operated. If you find a blown fuse, replace the high voltage diode in the magnetron power supply and replace the 'stirrer' (a fan-like device located under the sheet metal wave guide where the microwave energy enters the cooking cavity). It has a plastic bearing that can arc across inside it and short the energy out.
Sep 18, 2009 | Maytag MMV4205 Microwave Oven
Maytag MMV5207A Microwave Oven Logo
218 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
