Question about Dell Inspiron E1505 Notebook
Re: Volume dropping in and out while recording audio.
Hey Walter, thanks for answering my question so quickly.
Is it at all possible to avoid resoldering the motherboard? Could I maybe buy an external USB sound card and disable my internal one?
  • Dell Master
  • 998 Answers
I’ve never tried using an external USB sound card before but apparently they are available. As far as disabling your existing sound card, check in the BIOS (Setup Menu <F2>). It is also possible to disable under “Device Manager”. Here’s a link to service and owner’s manual for your model: http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 30, 2008
How do I fix a volume / sound problem on my kustom 2x12 amp
You have a bad potentiometer which is a variable resistor. Might be the switch you are turning.
May 08, 2017 | The Audio Players & Recorders
Is it possible to hook up the rs 125 so that both the tv sound system and headset sound system still operate together
The headphone socket has a built-in cutout contact that cuts the TV speakers as soon as headphones / headset is plugged in.
A work-around, at risk of impedance errors with the TV is to 'tap off each loudspeaker with a series resistor, each about 1K or so, a series audio-grade cap to normalize the bias, fed to a small 'headphone' amplifier that has a volume 'level' control.
The IK 1/2W resistor drops the AC audio going to speakers to a lower level, so that mini-amp doesn't clip.
It also raises the total parallel impedance to what should be a safe load on speaker channels.
Use screened cables to avoid 'hum' pickup.
Apr 07, 2017 | Dayton Audio Players & Recorders
Where do I find the volume to hear the recording on the Sony DSC-S650. After I record, I can see the recording, I can'nt hear the sound. Thank you, Walter
Check your menus.
Look for sound on, sound off or some such option.
Most digital cameras have an internal option in the menus to turn off the sound.
Also there should be options to make various parts of the camera sounds to be louder or softer. these are usually for start, shutter button, and others.
Hope it works.
Jul 10, 2011 | Sony Cyber-shot DSC-S650 Digital Camera
Hey. Im having a problem with my samson g track when mixing down midi and audio. The midi comes out really quiet even though its on full volume. It doesn't mixdown correctly. I'm also finding it impossible...
MIDI isn't audio, think of it as a sheet of music. It still needs to be played to be heard. Not sure of your recording setup but the midi performance that you have needs to trigger a keyboard or drum machine or VST instrument of some sort.
Apr 01, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Cannot play sound on my computer
take a look at your quick launch tool bar (the little arrow nex to the clock.) run your pointer over each one of them and see if any of the audio device is running. if so, right click on theicon and exit or close.
please rate the answer if that solved your problem
thank you
Oct 16, 2008 | Computers & Internet
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Logitech quick cam communicate stx on Vista - microphone not working
Why isn't the microphone on my camera working?
trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Mar 25, 2008 | Logitech QuickCam Communicate STX Personal...
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
Dell Inspiron E1505 Notebook Logo
70 people viewed this question
Alun Cox
