Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
GE Gas Range Serial #317B6641P001
After using the oven, it was turned off and a few minutes later an F2 code kept coming on.  It would clear for a minute and then come back on along with the beep.  I don't know how i did it, but I finally was able to stop it from beeping.  I haven't used the oven since then, for fear that there is something seriously wrong with it.  Could you please give me an idea as to what would be causing this.  Thank you
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: My oven keeps beeping F2
checkout this link...
http://forum.doityourself.com/showthread.php?t=75624
Posted on Nov 04, 2007
SOURCE: F2 Code Problem
I can't take credit except searching and found this info.. I will order to see if it fixes my error messages..Tom
All, I hope that this helps everyone having this annoying problem. The problem is the F2 error that seems to come on everytime you use the oven. Well, it was driving my wife crazy, so I finally gave in, and had a GE technician come over to fix it. :) It cost me $190, with $80 for the part and $110 for the labor. Had I known what the problem was, I could have fixed it myself in 10 minutes, and only would have had to buy the part. My loss is your gain. The technician replaced the sensor, part #WB21X5301 (can find at (www.geappliances.com (http://www.geappliances.com)); cost is $76. If you open the oven door, the sensor is on the top left-hand side and is long and skinny. Instructions come with the part to replace it. Basically, you unplug the oven, take out two screws, and cut the two wires to the sensor. You then use wire nuts to connect the new sensor wires, and push the :) wires out of the oven area into the back panel. That's it. Problem fixed. Glad I could help out others!! Merry Christmas! JakeDecember 11th, 2005, 02:25 PMThanks for the information and update back on this problem you had.:)
You can also buy that same part#WB21X5301 from here, abit cheaper:
Oven sensor assembly (http://www.repairclinic.com/referral.asp?R=1265&N=252618)
Posted on Aug 27, 2008
Krazytech
  • 725 Answers
SOURCE: F7 code flashes and beeps
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Sep 21, 2009
Icebassman 5
  • 57 Answers
SOURCE: F2 and F3 Errors just started on my GE Electric Range
Try to unplug the oven for about 10 minutes. It might reset itself.
Iceman.
Posted on Nov 10, 2009
Testimonial: "Thank you very much Iceman! Prompt and helpful."
blueextc3221
  • 15935 Answers
SOURCE: display panel on stove not working properly, cannot use the oven
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%$tr
Posted on Oct 01, 2010
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
Ge range 317b6641p001
Get an oven thermometer to see how off the temperatures really are.
Dec 17, 2013 | Kitchen Ranges
My GE XL 44 oven will not come on
Does the igniter glow white hot when you try to start the oven?
Apr 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
I have a GE Profile Gas/Electric Oven Range that has stop working
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Nov 21, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
843 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
