Question about SanDisk Sansa e250 MP3 Player
My Sansa Dose not tern on at all HELP!!! Please
I was useing it the pluged it in to the computer To charge but nothing happened then I took it off the computer and now it wont tern on Help please
  • 8,596 Answers
Helpful hints
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My sansadisk clip works, but when I plug the USB cable into the computer it switches itself off. If I plug the USB cable into the sansa without attaching it to the computer its fine, its only when I plug...
Hello, I Think what you to do is detach it from other power source and try pluging to the computer first and see the resault it gives to you. I hope it works for you. Please vote me.
Mar 22, 2011 | Computers & Internet
My player simply stopped playing in the middle of a song. Now it is simply dead in the water, absolutely ro response at all. Only two months old. ScanDisk sansa clip+ 4GB
mine did the same thing. like the battery went dead.. tried to charge it a few times, from the wall outlet and from the computer. nothing happend. then just by chance more than anything else i had it pluged in to the computer when i turned on the computer and it started working. not sure if that was the fix or not. just know it didnt work when i pluged it in when the puter was already on..
Feb 22, 2011 | SanDisk Sansa Clip MP3 Player
My computer cannot detect my sansa e250. When i connest the usb theres nothing happen, it only charging. Please help w/ this problem.
The power and data wires inside USB connectors are separate, so it's possible you have a bad cable.What operating system are you running on the computer?
Aug 14, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
Aug 05, 2009 | SanDisk Sansa e200 MP3 Player
Frozen
take the battery out
Jul 10, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e260 4gb player wont turn on at all nothing is happening with the blue ring or when pluged in to the computer it just stopped working after I pluged into the computer to charge
It's dead. Throw it out and buy an i-pod. My e280 did the
same thing. One day: fine, the next day: Blue Ring of Death.
I have tried everything on the internet, even downloaded Ubuntu and typed in all the e200tool Nuclearscriping BOARDSUPPORTSD and Manufacturing Mode commands. Nothing. It's dead 2months out of warranty. Piece of %$#@!!
Jun 02, 2008 | Audio Players & Recorders
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 is not recognized by by computer
**** this sansa e260 the piece of **** froze on me twice and both times i took it back to circuit city and just got a new one. one suggestion when you do get this is keep the repeipt for it
Mar 31, 2008 | SanDisk Sansa e200 MP3 Player
My Sansa m250 does not appear!!
Try this ... Press Menu button, Go to Settings, Go to USB, Highlight MSC and press the white button. Now, connect it back to your computer and see in Explorer if it picks it up as a separate drive labeled SANSA.
Also, make sure you are loading songs into a separate folder. I named my folder TUNES.
Nov 29, 2007 | SanDisk Sansa m250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
